Windows 98FE will not see my USB corsair stick nor ext Maxtor USB
My win98 first edition does not see the usb port when I connect devices to it. I tried connecting my Corsair 8gb memory stick and my maxtor 200gb external HD via USB port but my old laptop running win98FE does not see them. I am looking for a driver to install for the can be recognized. Is there assistance?
    Scholar:
  • 77 Answers
What you need is a USB mass storage driver, check out the following link for a download:
http://www.technical-assistance.co.uk/kb/usbmsd98.php
Posted on Mar 12, 2009
My maxtor 500gb usb hard drive is not responding when I plug to my pc, so I can't access to any of my file
hello,
-make sure that the cables from the ext hard drive is properly connected like power if there is and USB -try other USB port -try other USB devices -try other USB cable for that Maxtor -try other computer
the reason why you are doing that is to know if the USB port is broken of if the ext hard drive is not responding.
cheers.
Feb 24, 2011 | Maxtor BASICS Personal Storage 3200...
All External storage devices "USB Device Not Recognized"
Dear Sir,madam
You have to do some steps about fixing this problem :
1: Go to Device manager by right click on my computer then manage and then device manager.
2: Go to universal serial bus controller and export it.
3: in each USB root hub right click and then properties.
4: In properties screen select power management tab and unmark on " allow the computer to turn off this device to save power ".
5: After finishing this steps in each USB root hun restart your computer and then done
Jul 24, 2010 | Microsoft Windows XP Home Edition
Win98 does not recognize the Maxtor OneTouch III 500Gig.
First I will want you to know that support for win98 has long reached end of life. I don't think that win98 support mass storage unit of that capacity. I will suggest you opgrade your os to winXP
Dec 28, 2009 | Computers & Internet
Maxtor 120 gb harddrive cant read it on older home pc
You indicated that you have 2x achieved connectivity on the home pc. This is a good indication of a problem with the USB port. You may want to acquire a USB card for the motherboard. This alternative access to the computer could solve the problem. Cost for a replacement card can be as low as $20. Use a screwdriver to open the case, install the card and go.
Jan 20, 2009 | Computers & Internet
Maxtor One Touch 4 is beeping when I connect it by usb
Does the HDD spinup?
My slightly educated guess... the Ext 2.5in HDD requires more power than it is getting from the single port.
1. Try another port
2. Try it on another computer (all USB ports do not provide 250ma to a load)You may be sharing this avail voltage with all plugged in devices and will have to pull 1-2 others to get the HDD online. Since STARTUP current is high, the HDD pulls all it can from the ports (logical) then settles down and uses 1/3 to keep spinning. After the HDD is up and online, try plugging the other USB devices back in, 1 at a time. If it stalls the HDD - you know the why
3. Take it back and find something a bit less power-hungry (Like Hitichi or Toshiba)
Jan 16, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Connecting a maxtor one touch 111 60GB mini edition to a computer using MS windos 98SE
The maxtor is a usb2.0 device. Given that you are using Win98 I would guess that the computer is fairly old. It probably doesn't have usb2.0 ports. Also Win98 had very poor support for usb - even in SE. There may be a software solution out there and you may be able to get a usb2.0 card but.......
good luck wimancec
Aug 18, 2008 | Computers & Internet
I have Windows 98 and I need to download drivers for my USB DRIVE HOW AND WHERE CAN i DOWNLOAD
First you need win98SE (the Second Edition), still not sure that it will work I guess you try to conect a USB 2.0 device, I think that it will be better if you buy a 4 port USB 2.0 PCI card, install in an empty mainboard slot then install the USB drivers that come with the card and connect the device, be sure to ask the dealer for compatibility before you buy.
May 04, 2008 | Computers & Internet
USB CONNECT ONE FOR POWER+DATA ? AND THE OTHER POWER ONLY?
It sounds like your USB ports just aren't putting out enough power for this device. Did the drive come with an external power supply? If so, does it work when you use the external power supply?
Jan 12, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor onetouch iii mini 120GB
Is it of the same config? Are you hot swapping while the network is active? Do you have any redundant drives on the server?
Oct 24, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Computers & Internet Logo
169 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
