Question about Amana RanARG7302 Gas Kitchen Range
Amana ARG7300w oven inop
Oven will not work for Baking, broil and clean, the stove top burners, clock and oven light work. When turned on there is no gas smell and the burner does not get hot and it appears the pilot light is out.
  • 2 more comments
  • Robert Williams Aug 06, 2007
    The oven must have a pilot (no clicking). I tried to relight it but I could not get it to relight and I didn't see a button or switch to hold while relighting
  • Anonymous Nov 08, 2007
    burners work but not stove
  • sevilla6808 Dec 15, 2008
    My oven is not working, no gas smell when I try to turn on. The top burners and lights work well
  • Anonymous Mar 15, 2014
    amana gas oven burners won't light
It has a bad oven igniter.
Posted on Aug 27, 2007
  • ptoon Aug 27, 2007
    It has a bad oven igniter. I have the same problem...
I believe this model has a glow bar (hot surface igniter).  I can see the bar slowly get bright when I turn the knob, but no gas smell, and no heat.  :(
Any thoughts?  Like the OP, my burners work fine, etc.
Posted on Oct 23, 2007
  • Taliesin Oct 24, 2007
    I don't know if this is the OP's issue, but I think my issue is that of a worn out glow bar igniter.  I let the glow bar sit there all lit up for awhile, and when the oven got a little warmer, the gas kicked on and everything worked fine.  Maybe about 1.5 minutes.  I have been reading in other places that this is symptomatic of a bad glow bar.  Replace the glow bar, it heats up the over faster, which kicks on the gas sooner, which ignites and cooks my food.  :)
    Hope this helps.
    Just saw that PTOON posted that as well.  I already rated his on accident, or I would have rated it higher.  His was the correct answer.
  • 640 Answers
Does the oven have electronic ignition(you will hear a tap tap tap )noise when you turn the oven on? or do you have to manually light the pilot?
Posted on Aug 05, 2007
Stove does not work
sounds like youtr circut board is burnd out.also im not sure if youre model but some frigidair stoves had a callback because of the short problem .the were seting houses on fire.call youre local appliance dealer and see if youre model falls under this catigory.if i were you i would not use this unit it could result in a electricle fire untill you contact local dealer.
Apr 07, 2013 | Kitchen Ranges
I have a Gas Amana Range. The stove top works fine, but the oven will not heat when I select a temperature or broil. I can hear it making noise, but still no heat!
Hi.
If the oven is not baking or broiling test the temperature probe sensor located inside the oven cavity. To test the sensor read impedance (Ohms) using a multimeter. If the reading is infinity, then the sensor must be replaced.
If sensor is OK, the problem is usually either broiling or baking. In that case check igniter and valve coils, the flame sensor does not fail very often.
Regards.
Ginko
Jul 08, 2011 | Amana Kitchen Ranges
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
Bake and Broiler do not work
it sounds like you have a bad eoc which is electronic oven control that is the only thing it could be if your top burners are open
Dec 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Freestanding Electric Maytag Stove /Oven (with 4 burners self clean w/clock)
I WOULD LOOK AT THE DOOR LOCK ASSEMBLY AS THE DEFECT. THERE IS USUALLY A SWITCH THAT TELLS THE CONTROL IF THE DOOR IS LOCKED OR NOT. IF THE SWITCH HAS SHORTED CLOSED, THE CONTROL THINKS THE DOOR IS LOCKED AND WON'T DO ANYTHING BUT CLEAN.
MOST OF THE ASSEMBLIES ARE UNDER THE RANGE TOP.
YOU MAY HAVE TO REMOVE TWO SCREWS FROM THE UNDERSIDE OF THE TOP AT EACH OF THE FRONT CORNERS. OPEN THE OVEN DOOR TO GAIN ACCESS.
IT WILL BE LOCATED IN THE CENTER. THE DOOR HOOK THAT STICKS OUT TO ENGAGE THE DOOR IS PART OF THE DOOR LOCK ASSEMBLY.
Apr 04, 2008 | Kitchen Ranges
Amana Range, Electric wont bake or broil
the fact that the time keeps flashing is odd, an you set the clock?? and if so does it return to blinking again???sme stoves wont allow proper operation of oven without the clock being set.
Mar 23, 2008 | Kitchen Ranges
Amana RanARG7302 Gas Kitchen Range Logo
1,587 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
