Question about Jura Capresso C1000 Espresso & Coffee Maker
No water pumping
I just picked up a C1000 that hasn't been used in a while from a neighbor. I tried going through the "first time prep" procedures, however all 4 lights on the front continue to blink and no water comes out of the machine. I can't run any of the cleaning cycles because it always comes back to this. I called support today and the guy said it sounded like the pump was broke and it would be $200 to repair. Granted $200 is cheap for one of these, but that's why these have always been to rich for our blood. Is the pump something I can replace? Any other ideas what could be the issue?
  • 14 Answers
SOURCE: Fixing our Capresso C1000
What part do you need?
Posted on Aug 03, 2008
SOURCE: Jura Capresso Impressa S9 -water won't pull into the unit
I had the same problem and was about to take the machine apart when my girlfriend suggested I call customer service instead. Turns out when changing the filter, the air inside the new filter got sucked inside the machine causing a solenoir valve to airlock shut. You need to immerse the new filter in water before installing in the tank. All you do is keep pressing the steam button for 10 or 15 minutes at a time to jar loose the valve. Make sure you give the pump a rest every 10 minutes or so, or when the sound changes significantly so you dont burn it out. I did about 5 rounds of this yesterday and gave up, thinking I need to take it in for service....turned it on this morning for a few pushes and it worked. Be patient.
Posted on Dec 07, 2008
EsWorld
  • 1618 Answers
SOURCE: Jura C1000 - All red and green lights blink alternately.
Machine is not getting water.
Posted on Jun 30, 2009
SOURCE: Declcification Program not working
Call Capresso co. at 1-800-220-5701. I had a problem and I received excellent help, a step by step walk -through which got my machine back to service. Great machine! Great help!
Posted on Jul 08, 2009
  • 60 Answers
SOURCE: Jura S9 coffee machine not drawing water - says FILL SYSTEM
I think the magnetic valve is defective. This is located on the left side (seen from behind inside the machine) and there`s connections between the thermoblock and the hot water outlet. Try to press the steambutton and check if the magnetic valve clicks, and maybe check with a voltmeter if it`s receiving power.
PS. During steamprocessing the pump just have small ticking sound, and not the same sound as during brewing. There is no way around this Fill system message, and the reset function is not activated until any System Messages has been clared.
Posted on Jul 12, 2009
I dont have power going to my air ride pump? What could it be
Fuse , relay maybe.
Fuse #109 50 amp . under hood fuse/relay box .
Air Suspension Compressor Relay, 4.6L C1000
Near right headlamp
Air Suspension Compressor Relay, 5.4L C1000
Near right headlamp
Feb 19, 2017 | Cars & Trucks
Enith carburetor diagram
Nobody has messed around with the ignition timing in any way?
If it has stood for a long time(i.e years..) the fuel may have degraded to the point that it\'s useless.
The carbs will smell of fuel, but are you sure that fuel is being pumped to them in sufficient quantity? Try disconnecting a fuel line, crank the engine a few revolutions to see if fuel is pumped out.
Try gravity feeding the carbs. Use a can of fuel connected to the carbs, held above the engine. Get somebody to crank the engine and see if it fires up. If the engine fires up, suspect the fuel pump.. or fuel lines.
An air leak can also cause non-starting. The usual cause is the inlet manifold gasket. Any air leaking through the gasket can cause your non-starting problem. Go back and check that no dirt has been picked up by the gasket before you fitted it/it hasn\'t been ripped. Check that the inlet manifold has been correctly tightened.
It doesn\'t sound as though you have much of a problem .. more of a \'niggle\'.
The link is for Zenith carburettors:
Zenith carburetor Google Search
Aug 20, 2014 | Cars & Trucks
Model gfwn1100 front load washer
It shuts down because of time out, is the water turned on, sounds stupid but it has happened several times, I go on a service call just to turn the water on to the machine.
Feb 03, 2014 | GE Washing Machines
Pump switches on and off when water is not running hasn't been used for a while
The check valve on the pump is bad causing water to fall back down drop pipe and triggering the switch to turn the pump on over and over. Replace the check valve.
RJ
Mar 12, 2012 | Plumbing
How do I change the water pump?
what vehicle is it? let me know then perhaps i can help,
May 14, 2017 | 1990 Nissan Pulsar
Alarm started and will not switch off. Siren goes all of the time unless circuit breaker furthest to the right is switched off, then lights and water heater do not work. The alarm was not operated, in...
open the fuse box and look at the outlet side of the circuit breaker ,then remove all the tails and then connect them one at a time so you can isolate the alarm feed and leave that disconnected
Jul 19, 2011 | Car Audio & Video
I need to clean my capresso c1000. i can't find the instructions. i put a cleaning tablet into the ground coffee area, and ran the ground coffee button a few times. is that it?
No, first push the self clean button (hold until lights come on). Then pull the grounds unit and empty it, that will turn off one red light. Fill the water tank. Then drop the tablet. Then hit the ground coffee button. Cycle through and dump the grounds each time the grounds light illuminates.
Jul 09, 2011 | Jura Capresso C1000 Espresso & Coffee...
I prime the pump, and the sprinkler system does not hold pressure. I have also tried to prime the pump from the intake side. what happens there is that the pump actually begins to shoot water back out the...
You can't prime the pump with the same water source you are trying to build pressure in. Shut off all the water going to the house, use the neighbors hose or have several gallons (maybe 5) to prime the pump and continue priming pump until it starts to build head pressure then plug prime hole.
RJ
Jul 05, 2011 | Flotec Corrosion Resistant Shallow Well...
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
Jura Capresso C1000 Espresso & Coffee Maker Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
