Question about Food Mixers
Braun km32 need spare parts for Braun Multimix KM 32
SOURCE: I need a replacement bowl for the braun km32 mixer
I have an extra bowl, but am in need of a regular whisk...any chance you have an extra and we can trade?
Posted on Jun 26, 2010
SOURCE: Braun MultiMix 880 became a one speed. Is a
Apparently the switch is very easily available, unknown for what reason. In Europe they say it is not available at all anymore, which I find strange.
However!
Dissasemble, by removeing base plate and screw underneath curved retainer plstic clip in the front. Then gently pry apart with blunt, thin object to split the two halves. Remember to unplug the power cord first. Check the circuit board for cracks, or burnt components. Then suspect the triac/tyristor. Desolder it and test it with a multimeter. (google "test triac multimeter"). Then note the code on the front of the triac, and search for a supplier of electronic parts to get hold of a new one and solder it back on. Note the orientation of the pins, and reattach heatsink if fitted. (Euro version have non.)The triac often looks like a flat design transistor and have a code/part nr that may look like; TCI 226 N, as on my European 230v version. Electronic components suppliers also have interchangeability lists for different manufacturers and use cross reference lists. Should only costs a few dollars or so. Triacs tend to stay fully open when failed, causing full speed in any mode. It is worth a shot.
Posted on Nov 29, 2010
SOURCE: I need a chopper attachment
See
http://www.smallappliance.com/product.asp?pid=5623&cur=USD&sid=18956&mid=5&gid=18978&prdCls=P&PartsPaNu=1&shopBy=Brand
(2 pages)
And you will find spare parts online for your braun which i believe is model nr 4642 (se baseplate).
For a chopper attachment; you may need bowl plus rotating blade.
You may also use braun's own spare parts finder at:
http://www.service.braun.com/product/product.asp?rg=NA&c=US&l=GB&typ=pf&frmTyp=s&grp=0&s=4642&subgrp=&des=&sgrp=s&sString=4642'HH'HH06'H'MultiMix&seite=2
But you will have to contact one of the authorised service partners to buy.
Posted on Nov 30, 2010
SOURCE: My Braun Multimix 280 will only operate on
Yes. You can do two things. Replace the swith curcuit board or replace the triac/tyristor on the board itself. The last solution requires you to unsolder the triac and loosen it from the heatsink(110v veriosn only. 230v version has no heatsink) and test it with a multimeter to establish if it has failed. (Testing of tracs can be googled.) In eather case you will need to open the casing.
1. remove the base palte by lifting the end opposite to the electric cord.
2. Loosen the bottom power outled slider, without removing it fully
3. unclip the curved plastic retainer in the front and unscrew philips head screw.
4. Work around the edges of the two halves until it comes apart and you are able to free the slider from its return spring.
Replace the cicuit board completely if available. Or resolder a new triac observing the orietation of the pins and reattach to the heatsink by riveting/cliping on or whatever applies to you model. Using heat conductive silicon paste between triac and heatsink is a good idea if it is originally fitted (if white paste residues can be seen). The European 230 v version do not have a heat sink, due to the higher voltage and thus lower current opassing through. If the Euro version, simply replace the triac, trim the pins on the back of the board nad put back in place.
Triacs can be obtained from any electronic componets dealer, as long as you can supply the code stamped on it. The Euro version has code TIC226N, which you can find in any component or manufacturer cross refereanse table. TIC226N basically means a 8 amp triac. Triac is simplified just a sort of ac transistor. The US version I do not have the code for, but it must have a higher ampere rating, thus the heatsink
To replace;
Put all internal componets back in place in the right halve. Put the left halve on top and fit properly by gently pressing together. Fit the screw in the front and the retaining clip. Fit the sliding cover by cliping it back on, observing that the notch for the return spring will meet the spring pin on the right side for it to snap in place. The spring pin can be observed through the slots for the sliding cover. Then insert the base plate reversely of how you removed it.
The problems of these mixers, is that if overloaded the maximum current rating of the triac's may be exceeded. This will cause the triacs to short curcuit and therefore will give full power in any mode.
To avoid the problem, avoide heavy batters, heavy doughs and prolonged high load tasks. Otherwise a very handy smart little mixer that should last for years.
Posted on Dec 01, 2010
SOURCE: braun multimix 280 watt hand
Please see solution at this link on Fixya
Oil required for Braun mixer KM32
I understand the KM32 mixer uses 4.5 oz of Food Grade Mineral Oil in the gearbox, but haven't found a source. Will try Restaurant Supply house or appliance repair.
Feb 11, 2013 | Braun Food Mixers
Braun 4642 Mixers user guide
http://www.user-manual-pdf.com/appliance/handmixer/braun/instruction/braun-multimix-4642-handmixer.html
Nov 12, 2012 | Braun M880 MultiMix Hand Mixer
Hello, I have a Braun multimix 220 watt, and just recently it has stopped working. The blades turn but when I try to use them to chop (eg onions, mango) they get stuck and the motor just makes a whirring...
It sounds like to scnearios are likely; First, the gears inside the mixer can brake if overloaded, and secondly the motor may be damaged. If the motor is damaged, it usually makes extra noise when running, sparks may fly, and overheating and burnt smell can be observed. If not it is probably a broken gear or two. The gears for this mixer can be obtained as a kit containing all the nylon gears and they are quite reasonably priced. You will need to open up the mixer by splitting the two halves. Spare parts can be found either from your local supplier, from braun.com online or any other online supplier of parts. Please see this link for information on how to open it up to access the gears.
http://www.fixya.com/support/t3875766-braun_multimix_280_will_only_operate
Apr 30, 2011 | Braun M880 Multimix Hand White Mixer
Braun multimixer m880 the motor has finally died,
See
(2 pages)
Oct 14, 2010 | Braun M880 MultiMix Hand Mixer
I need a chopper attachment for my Braun M880 multimix hand mixer
See
(2 pages)
Sep 01, 2010 | Braun M880 MultiMix Hand Mixer
Need Spare Whisks
See
(2 pages)
Aug 07, 2010 | Braun M880 MultiMix Hand Mixer
I am looking for whisk set for braun handnmixer ultramix
Get the type number from the base plate and visit www.smallappliance.com for purchasing attachments. Or check out braun.com and use their spare parts finder.
Jul 20, 2010 | Braun M880 Multimix Hand White Mixer
Jun 21, 2010 | Braun Food Mixers
Necesito un recambio para un multimix braum m880. ¿cómo lo puedo pedir? gracias. mi email: fanyclarinet@hotmail.com
According to my limited spanish I assume you need spare parts?
I suggest braun.com internationally, and also smallappliance.com if you live in the US.
You will find the 4-digit type number required on the base plate.
Feb 17, 2010 | Braun M880 MultiMix Hand Mixer
I've lost the blade for my Multimix 280 watts that goes in the chopper. can I order a replacement?
Yes. You can find spares at smallappliance.com. navigate by brand and category.Your 4-digit type code can be found on the base plate. Otherwise, you can use Braun.com and their spare parts nr locator by searching for the 4-digit product code. Note the number and contact one of the authorized dealers from the list.
Dec 17, 2009 | Braun M880 MultiMix Hand Mixer
Food Mixers Logo
22 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
