Question about Insignia IS-LCDTV32 32 in. Television
Can only get 13 channels
Attempt to scan and t.v and it won't add channels.
  • jreeves816 Mar 12, 2009
    Thanks alot fixed the problem.....Cheers...
  • Anonymous Mar 14, 2009
    same as above
  • 89 Answers
Make sure you are in CATV mode before you scan, You are switched to antenna mode and will only get the first 13 channels if actually hooked up to cable
Posted on Mar 12, 2009
On olevia tv, channel scan will not pick up channels 3 to 13
i think the low band on your tuner has failed
Nov 16, 2014 | Olevia 332V LCD TV
How do I reset my kenwood TK-3212L
ADD TO SCAN/ DELETE FROM SCAN
Press the key programmed as Scan Delete/Add to add or
remove each channel to or from the scan sequence.
• The channel add indicator ( ) will appear on the
display when the selected channel is added to the scan
sequence.
Press and hold the key programmed as Scan Delete/Add to
add or remove each zone to or from the scan sequence.
• The zone add indicator ( ) will appear on the display
Oct 14, 2014 | Radio Communications
One radio clicks when the other is mic
Scanning is interrupted when you key the other unit's mike. For example, if the non-scanning unit is set to channel 13 and keyed scanning will stop at channel 13 on the other unit to establish communication between the two.
Nov 07, 2013 | Midland LXT310 2-Way Radio
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
How to add channels
Try doing the auto scan first to get all the possible channels.. Usually the Add/Delete function applies once the TV knows what channels are out there to add or delete.
Jan 23, 2018 | Emerson EWC1303 13 in. TV/VCR Combo
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
{TAB} after I scan barcodes??
I just had to do this today... took me a while, but I figured it out. Download the manual from here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Scan the following barcodes in order and it will add a tab to the end of the barcode you scan.
Scan "Scan Options" Pg 13-6
Scan "<Data><Suffix>" Pg 13-7
Scan "Scan Suffix>" Pg 13-5
Scan "7" Pg Appendix D-3
Scan "0" Pg Appendix D-1
Scan "9" Pg Appendix D-4
Scan "Enter" Pg 13-8
You should now have a tab at the end of any barcodes you scan. Hope this helps!
Mar 03, 2010 | Symbol LS2208 Handheld
We are receiving channels 1-13 only; don't know how to add more
make sure you have your tv set to cable, if you have a set top box unplug the box plug it back in reboot it, like i said make sure your tv is set to cable then do auto channel scan should work good luck!!
Apr 12, 2009 | Toshiba MD20Q41 20 in. TV/DVD Combo
I can't get all the channels using the remote
I enter the menu button, channel, add, and it begin to add the channels for cable.
Feb 13, 2009 | Disney DT1300-C 13" TV
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
Insignia IS-LCDTV32 32 in. Television Logo
158 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
