Question about Radio Shack Radio Communications
Require manual /frequency
Require manual frequency
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Radio Shack Master
  • 102,366 Answers
What make and model scanner?
Posted on Apr 23, 2013
Require manual and frequency
Apr 23, 2013 | Radio Communications
Icom v-68 no transmit no recieve
To help you resolve the issues with your radio, much more info is required. What frequencies are programmed in your unit, is it VHF or UHF, this is required before we can begin. Do you know if the radio has frequencies programmed in the set, if not, that would be the obvious reason why you are not able to use the set.
Be that as it may, i do have a solution, but bear in mind what I have stated re: info required.
Join yahoo group SPECIFIC to your radio Make/Model, the technicians there will require as much info from you as possible regarding your set, so than can give you the solution to the problem, plus you can download manuals, schematics and software and all this is completely FREE.
I hope I have been helpful.
Best regards,
Peter
Mar 06, 2013 | Icom Radio Communications
Radio will not recieve
Hi Andy,
What you have is an amateur radio which requires a license to operate it.
Having said that, I don't know where you got the unit from, but obviously, the unit has had the frequencies deleted, so you cannot operate it until you go to a radio workshop to have the unit re-programmed.
You will only get receive(RX) frequencies programmed, no transmit(TX) frequencies. Sorry, but if you want to operate this unit, you will need to approach the Wireless Institute of Australia(WIA), who are responsible for licensing of radio amateur operators in Australia.
web:www.vk6wia.net for all the info re: licensing requirements.
Cheers,
Peter
Mar 02, 2013 | Yaesu FT-101ZD Owners Manual
Date and time appears scanner doesn't scan
Hi June,
Has the radio scanner been programmed with frequencies?
If not, that is the answer to your query.
All radio scanners need input to function as they should, no input, FREQUENCIES, no go.
If you have the user manual handy, it will guide you through the steps required to program frequencies into your scanner.
If you don't have the manual, then going to your local Radioshack store would be of benefit to obtain a copy.
You will also need a hard copy of frequency listings for your location.
these can be found by a simple google search.
I hope this has been useful to you.
Cheers,
Peter
Feb 26, 2013 | Uniden BC370CRS Base Scanner
What frequencies I can use vertex VX 400 U radio
Not sure what frequencies are allocated in India for UHF ham, but may i direct you to the following: join yahoo group specific to your radio Make/Model, there you can get info and you can download manuals, schematics and other goodies.
I'm sure, but not 100%, that ham bands around the world have similar allocations on 70 cm band UHF, but as I stated, not 100% sure.
Best regards,
Peter
Feb 05, 2013 | Radio Communications
To RESET all programs Frequencies on my IC-H16 portable radio.
You can download and review the manual for the Icom IC-H16/U16/U2 HT here. This radio is an Amateur Radio Service transceiver, and will require an FCC license to transmit. No license is required to monitor or listen to the radio. Keep in mind, the Amateur Radio Service is NOT part of "CB" or "FRS" radio services - neither of which require a license to transmit.
When you read the manual, you'll quickly see that there is no "reset" function available. There are only 16 memory locations, so you can simply lock out channels you no longer wish to monitor or you may program any valid frequency in the range supported by the radio. Doing this, in combination with setting the squelch or tone will prevent the radio from opening a particular frequency(s) when the corresponding memory location is scanned.
I hope this helps and good luck.
May 04, 2011 | Motorola GPS
I cant listen to the police
First, make sure that you have the correct frequency for your local police. You can find a comprehensive database of active frequencies in your area by visiting:
www.Reference.com
Program the frequency or frequencies using the instructions in the scanner's operating manual. and you should be all set. If you need the manual, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
NOTE: If the frequency database shows that your local police are using a trunked system, you will not be able to monitor them using the BC60XLT-1. Trunked systems require a trunking scanner. Many law enforcement agencies are also using digital systems for their communications. If that's the case in your area you'll need a scanner capable of monitoring APCO-25 digital transmissions.
Bill B.
Listening in since the 60's
Nov 13, 2010 | Uniden BC60XLT-1 Handheld Scanner
I have a Raymarine 240 VHF from the USA and I need to get it switched for Australian use (VHF Channels - Frequencies) ?
Hi Michael
From the owner's manual (Page 14) you need to press "menu", then select "Frequency Group", then you have the choice of USA, Canada or International channels:
Here's the link to your owner's manual should you require it:
http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=830&PRODUCT=1948
Hope this is helpful to you.
Sep 06, 2010 | Raymarine Ray 240 Modular Vhf System
Wrong time on Emerson Smart Set clock
This is a problem with the clocks tuning crystal. Digital clocks have a crystal that is tuned to run at a certain frequency to keep the clock working correctly. These clocks have a problem with that crystal keeping the frequency locked at the correct working frequency. This problem will sometimes cause the clocks to run fast due to a running frequency higher than the regulated frequency and sometime slow due to a running frequency running lower than the regulated frequency. The only way to fix this problem is to either adjust the crystals frequency to the correct frequency and lock it. Or change the crystal. Both these types of service require tools and test equipment to fix the problem. This is usually best handled by a service center. The Emerson customer support telephone number is 1-800-898-9020. Give them the make and model number of your clock radio and ask them for assistance. I hope this information helps you with your problem.
Nov 18, 2008 | Emerson Smartset Clock Radio
Memphis codes
Most scanners require you to program frequencies manually before you can scann them. Your instruction manual will tell you how to do this.
If you need Memphis frequencies, go to these links:
Memphis, TN
http://www.radioreference.com/apps/db/?ctid=2506
Memphis, AR
http://www.radioreference.com/apps/db/?ctid=125
Rollin Cbs
Dean
May 02, 2008 | Uniden BC244CLT Base Scanner
Radio Communications Logo
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
