Question about Thane Distribution Group H20 X5 5-in-1 Cleaning Machine with Steamer
X5 steam cleaner does not pump steam
Do you know what stops the steam being produced? Cleaned with white vineger and water but still no steam is produced. I can hear the pump working but nothing works. Cleaned nozzels and pipes too?
    New Friend:
Hey Shaun, I only bought mine a little over 12 months ago and the same thing has happened with little than average use. I got in contact with the company who sold it to me. They suggested I buy the hand held part and that was it. How ****. I'm going to use a household descaler
Posted on May 01, 2013
Bissell steam mop
-Pump is out (Broken). or water line is clogged.
Good Luck
Mai
Aug 19, 2014 | Bissell Lift-Off Steam Mop, Titanium, 39W7
Stopped emitting steam
Mine started steaming from the top and a little plastic piece inside where the handle attaches to the wand cracked. I had to purchase an entire head and after one use it did the same thing again. It is a poorly made steamer with cheap plastic parts! Since it was out of warranty, I threw it in the dumpster!
Mar 24, 2014 | Oreck Steam-It All-Purpose Steam Wand
X5 H2O Steam Mop dripping water from small hole at bottom and not producing much steam
john, I would try cleaning the mechanism with vinegar or CLR to dissolve any buildups you can't see. Rinse, fill up with fresh water and powerup. good luck
Mar 13, 2014 | As Seen On TV H2o Mop X5 5-In-1 Steam...
Bad fuel injector
White smoke is usually caused by water and Subaru 2.5 engines are known for head gasket failure which causes them to consume coolant and produce white smoke. Run a compression check if you have the capability to do that and see if there is a difference between cylinders that is greater than 10%. You can also check the spark plugs to see if one of them is cleaner than the others. If you find one that looks like it has been steam cleaned or is considerably cleaner than the others, you have probably found the cylinder that has the problem. Good luck.
Dec 24, 2013 | Subaru Impreza WRX STi Cars & Trucks
X5 steam mop, turns on but produces no st eam
Its likely that the tube that supplies the steam to the mop is clogged. you will need to disassemble the mop part and find that tube then push a wire up there to clear it out. Then turn the unit on and keep trying to clear with wire, you may want to wear a glove in case a sudden puff of steam comes out. This problem is common it happens because when you evaporate the water, any dissolved solids drop out onto surfaces inside the unit and make the clogs. The 'Motor' is real hot because the unit is making steam but it can't get out!
Nov 10, 2013 | As Seen On TV H2o Mop X5 5-In-1 Steam...
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    How can i fix my H20 mop x5 steam cleaner
    see this causes, and use the common sense God bless you
    nspect your steam cleaner's belts for loss or damage. Damaged belts can cause the brushes to stop rolling or the spray mechanism to stop functioning. To fix a damaged pump or brush belt, first unplug the steam cleaner. Refer to the user's manual to determine the specific location of each belt. Order a new belt directly from the manufacturer's website, or from a local home improvement store, if necessary.
    Sep 19, 2012 | Vacuums
    My Hometek Steam Penguin wont produce steam
    Hi
    I opened whole thing and found that no suction to the pump or pressure from the pump. Opened the clear box which contains the pump and the el-motor. Then I opened the white pump and found it was assembled wrong way round. There are two tiny one way silicon "valves" which should produce the flow of the water to the heater. I also wiped off part of the sticky grease away. Now it works. 4 hours work, but it was interesting to learn the function :) .
    Anssi
    Apr 09, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
    The steam works fine on my X5, but no water comes out of the coffee part. The pump sounds like it's working.
    Check the shower screen and the dispersion block for clogs, they need to be cleaned periodically.
    You can remove it by unscrewing a screw in the center of the shower screen.
    Mar 04, 2011 | FrancisFrancis! X5 Espresso Machine
    Thane Distribution Group H20 X5 5-in-1 Cleaning Machine with Steamer Logo
    234 people viewed this question
    Top Thane Distribution Group Home Experts
    john h
    Tom Chichester
    Are you a Thane Distribution Group Home Expert? Answer questions, earn points and help others
