Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
2000 sears craftsman garage door opener
I have rebuilt the unit, but the roiginal owner of the home did not eave the wiring diagram for the sensors and push button, I have a newer version but it has outlets for all 6 wires sears unit only has 3 they look like this 1 (red) 2 (NEC CL2) 3 (24 V)
I just need to know what wires go where. I do know that the 2 door sensor wires (4 split) are paired to give 2 lines and I assume that one goes to 2 and the other to 3 but am unsure of where the second line from the wall push opener goes
any ideas?
  • 504 Answers
#1 wire with red trace –
#2 all white wires with no trace
#3 wires with black trace
Posted on May 29, 2010
I have a chamberlain/craftsman garage door keypad from previous home owner and do not know the old password to reset my own. How do I reset the password without knowing the old one?
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Oct 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
No wiring diagram for the sensors
The solid white wires from the sensor go to terminal #2 and the wires with the black stripe go to terminal #3.
Jul 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I program a Craftsman Wireless keypad for Chamberlain garage door opener? I purchased the home and the former owner does not remember the code.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this button and then walk over to your keypad and key in any 4 digit code you want and press enter.
Make sure the battery is good in the keypad.
Feb 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Is there a univeral remote for craftsman garage door openers?
Depends on the age of the opener. The model number is on the end of the opener closest to the door. Using it go to Sears parts and you can find out if the remote is still available.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman opener model 41A43157D. It
That is not the model number for your opener. The model number is on the opposite end of where you found that number. It starts with 139. and you should be able to down load a manual from Sears Parts or you can google owners manuals.
Oct 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
My wiring for my garage door opener is messed up at the sensors. i am looking for a diagram to show proper wire connections.
If you look at the wires from the sensors you will find one wire from each sensor is solid white and the other is white with a black tracer. The white wire from each sensor goes to terminal 2 on the back of the motor unit and the white wires with the black tracer goes to terminal 3.
Oct 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wiring diagram for garage door sensers Garage Master 1/2 hp part # 41A4252-7G
Each sensor has 2 wires. One solid white and one white with a black tracer. The solid wire from each sensor goes to terminal 2 and the white wire with the black tracer goes to terminal 3.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wring sensors
whites together under 2nd screw, grays together under 3rd screw. both indicator lights (normally LED's) on the eyes (1 each) must be lit in order to operate. this is the basic set-up...if you give me your model number from the opener, I should be able to find a owners/users manual for the unit
please take the time to give this solution a fix ya rating
Thanks for using Fix Ya
clarkco
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
609 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
