Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
YS4500 steering issues
How do you to take off Red caps to fix steering issues
  • Mike Bilansky Apr 23, 2013
    Never mind I got it off.....
Where do. I locate the power steering fluid resevoir
The power steering resevoir is usually indicated by a red cap with a embosed picture of a steering wheel or road wheel on it. Sometimes it is not coloured but has the embosing on. If all else fails open the and look inside, the steering fluid will be red in colourl
Sep 03, 2015 | Cars & Trucks
How to clean the carburetor on a ys4500 model?
fist of all you need to know what you are doing when dealing with gas issues not worth playing with gas if you are not famliar with gas equipment play it safe and take it to a dealer or repair shop
Jul 08, 2014 | Craftsman 20 Hp 42" Deck Lawn Tractor
I'm having problems with the steering...is there powersteering for this particular car
Yes, you do have power steering. Exactly what is going on with the steering? Does the steering wheel seem to be jerking or twitching as you turn? You may be able to pour in some Honda steering fluid (or Import Fluid Approved for Honda). It will be a red cap to the right as you are looking at the engine. If this fixes the problem temporarily, then you need to find where it is leaking from to fix it.
Jun 06, 2010 | 1992 Honda Accord
I need to refill my power steering fluid and I do not know where to put it
u will see a container tub with black or red caps in the engine bay somewhere and read wat is say on top the cap ,is usally say power steering fluid or got a steering wheel picture on cap is either
Nov 05, 2009 | 1997 Mazda MPV
YS 4500 Stalls out after running for 20 mins
I do believe they change plug(s) and air filter? There could be impurities and water in tank. Check for any loose electrical connections. Problem with valve clearance. Keep me informed.
Jun 13, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How to remove snow blower from Craftsman YS4500 garden tractor
Go to www.managemyhome.com to download the manual for free. Just type in the model # 944606950.
May 21, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
1999 Lexus ES300 Steering wheel make groaning noise
Hi
If the groaning sound is still happening, you are probably low on power steering fluid. I suggest starting there. Remove the cap and check the dipstick attached to the cap. The reason the sound would go away at high speeds is that you don't turn the wheel as sharply at higher speeds so the pump is not trying to pump air ( that's the groaning sound ).
If you are low on PS fluid, fill it but check for leaks for a while. Look under the car in the morning for fluid. If you spot a leak, take it back to whomever replaced the hose and have them fix it.
As far as the engine light goes, first make sure the gas cap is on properly, meaning all the way. Turn it till you hear it click several times. If that is all it was, the light should go off after 20-30 miles or so. If it stays on, try changing the gas cap. That is probably one of the cheapest routes to go.
Good luck
Apr 12, 2009 | 1999 Lexus ES 300
The steering on my chevy is very hard making it
have the power steering pump checked, sounds like low pressure, a quick test drive by a front end tech will decide if the pump is the issue or the rack and pinion steering unit is the cause..
Apr 08, 2009 | 2001 Chevrolet Cavalier
Power steering light is on. have 2004 saturn ion. where do you check the fluid?
Should be a cap under the hood that says power steering fluid
Mar 22, 2009 | 2004 Saturn ION
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
