Question about Baby Gear
Chico foot rest
I do not know how to get the food rest to fold down. My sons legs are too long now
    New Friend:
  • 16 Answers
I believe you either pull out the knob on the sides of the foot rest or twist them
Posted on Apr 24, 2013
3 Suggested Answers
SOURCE: need directions on how to fold legs
Hi, I can fix this.
First, on the bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place.....
To unfold, simply press on the holding latches, and pull up.
Good Luck.
Gordon & Shirley
Posted on Feb 03, 2009
macnutz
  • 541 Answers
SOURCE: bugaboo bee i have a 2007 bee ant the foot rest
The foot rest is part of the frame and not available as a part. Plastic can be welded google plastic welders or bumper repair to find a local work shop.
If you find this helpful please rate it!
Posted on Oct 07, 2011
How do I add knit band to pajama pant on McCalls pattern 7975. I have lost the directions.
Usually the cuff ribbing is cut double the required length plus doubled seam allowances (ie 3" x 2 = 6; add two 5/8" for seams = 1.25"'; equals 7.25" long). It is doubled so when it is folded in half and stitched to the leg, there will be no seams showing outside). The width of the ribbing is probably an inch or so shorter than the leg bottom--it should be large enough for the foot to fit through but tight enough that it hugs (not squeezes) the leg.
Sew the cuff together lengthwise to make a circle. Fold it in half with the stitched seam inside. Then fold the circle widthwise with the seamline at one end. Mark the halfway point opposite the seamline. Then fold in half again with the seamline and the first pin matching together. Mark the other two ends. You've divided it into equal fourths. Repeat the same procedure marking the pajama leg in fourths. Then match the seamline of the ribbing to the seamline of the leg (right sides together). Match the other three marks on the cuff to the three marks on the pajama leg bottom. You'll have the stretch the ribbing because it should be a bit smaller in circumference than the leg bottom. Stretch the ribbing to match the leg bottom and stitch the ribbing and leg bottoms together. Turn right side out.
How to Attach Knit Cuffs to Sleeve Shirt Sleeves
sewing with knit fabric how to sew sleeve cuff with knit fabric
Jan 02, 2016 | Sewing Machines
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
May 29, 2012 | Furniture
Bugaboo bee i have a 2007 bee ant the foot rest part you know were they rest there legs is after snapping off,could i replace it and whats my best options
Oct 07, 2011 | Bugaboo 2010 Bee Stroller
How do I fold a maclaren quest pushchair?
You need to locate the lever standing out proud on the right hand side of the upright legs of the chassis, push this down with your foot, then push upwards the back folding section (referred to as a 'band-stand') with your foot, the stroller will then collapse by pushing this forward away from you.
Hope this helps.
Apr 05, 2010 | Maclaren Quest Stroller Standard
How do i fold the maclaren triumph
To fold the Triumph, stand behind the stroller (as you would if pushing it).
On the right hand leg (just above the back wheel) there is a small arm sticking out, push this downwards with your foot, then kick up the centre of the back support with your foot (directly behind where the child sits and looks like a band stand construction), then push the handles forward and away from you, the stroller will then collapse shut.
I hope this helps.
Nov 19, 2009 | Baby Gear
Have lost the instructions for britax vista buggy and can't remember how to fold it down (long time since used)
Although I cannot locate the instructions in an electronic format, looking at the image I would suggest that it may be the following:
Down the right-hand back leg of the stroller, there is a horizontal peg sticking out, push this down with your foot, this will then allow the pram to be pushed forward (away from you) and then folded. You should have a locking device on this to keep it closed. If the locking device is on now (an it's already folded) don't force it as you will break it.
I would ALWAYS recommend that you contact the supplier for advise also.
If you go to a local baby shop and ask them to take a look this will help, although I seem to remember that this folds and opens very similar to the Maclaren Techno XT.
I hope this helps.
Sep 14, 2009 | Britax Vista - Blue Umbrella Stroller
How do you fold the Exersaucer Smart Steps?
Onthe bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place..... The thumb laches can be hard just so you know
Jan 03, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
Need directions on how to fold legs
Hi, I can fix this.
Good Luck.
Gordon & Shirley
Nov 17, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Baby Gear Logo
115 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
