Question about Dba Archos 5 160 GB Internet Tablet with Android (501323)
Display is cracked internally
My x touch x906 z not working internal display has been cracked. please suggest from where i can fix it up. please suggest my email id is piyush.k4173@gmail.com your response will be highly appreciable.
How do you move internal storage to the sd card to free up internal space
touch the "Settings" icon, go down to the "Device" area, touch the "Storage" icon : go to the bottom of the screen, and select "Transfer data to SD card", then select the items you want to move.
You should also move some apps from internal storage to the SD card : "Settings", "Device", and touch "Applications" : then touch each and every application : for most of them, the button "Move to SD card" will be active, just proceed.
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
I bought sd card for it. want to download apps to it not to internal or nand memory. help please
That is not an easy thing to do. The best you can do is download the apps to the internal memory and then touch them one by one and see if there is an option to MOVE them to the external SD card. It has been my experience that not very many can be moved.
Jun 22, 2015 | Proscan 7-Inch Android Internet Tablet,...
My Kindle went blank with almost a white screen tho fully charged and now wont turn on at all. Have followed Amazon's suggestions but nothing works. Can you help?
Chances are your screen went defunct. Or it could be a problem with some other piece of hardware. You can try using the USB cord to plug it into the USB port on a laptop or desktop and see if the computer can read the files. If it can display and explore folders and files, chances are it's the screen (display) that went south. It it can't display and read folders and files chances are it's the memory or some other internal hardware that died. Sadly these things are cheaper to replace than to repair. I have a Kindle II with a faded out display. It works but the text is so light that it's barely readable so I retired it. I have a Kindle Touch that I dropped and the screen broke so I ended up getting a Kindle Paper White and I like it the best of them all.
Apr 22, 2015 | Amazon Kindle 1
Cracked screen on my Trio tablet, can see the display but it won't respond to touch. It's not under warranty. Can I fix it myself?
Yes touch screens are very sensetive.Because of the cracks on the screen ,the board can't read the command.The screen can be replaced only if you know what you doing however it can cost upto and around between $250 and $350 mark to repair by a professional.to get better ideas of what your up for research on Utube .
Jan 06, 2014 | Samsung Galaxy Tab 3 10.1" Dual Core...
Drop the tablet
The screen probably will have to be replaced but the fall may have caused internal damage so that even with a new screen the tablet may not work without further repair.
Dec 30, 2013 | Supersonic SC-91JB 9-inch Android 4.1...
RCT6378W2 Broken LCD
Only a computer repair service can tell you what is wrong after they repair the screen , we can not guess at all possible damage.
Feb 25, 2018 | Tablets & eReaders
Inside of kindle fire cracked
To get your kindle fire fixed your self would be a lot of work. I recommend you try to get it replaced by amazon. http://www.amazon.com/gp/help/customer/display.html/?nodeId=200127470 If it is fairly new it still might be under warranty.
May 28, 2013 | Tablets & eReaders
Dba Archos 5 160 GB Internet Tablet with Android (501323) Logo
Top Dba Tablets & eReaders Experts
Are you a Dba Tablet and eReader Expert? Answer questions, earn points and help others
