Question about OKI C5200n Laser Printer
When printing color image, color is to heavy/dark
  • 2,385 Answers
Adjust the print density from the properties of printer
Posted on Apr 24, 2013
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Acer Aspire 8920 screen image is good but prints very dark -
I'm sure you haven't used all printers. Anyway, are you printing color images such as pictures, etc. If so try using a glossy paper. The colors and images are much more true colors on glossy paper, and it don't **** up your ink.
Mar 28, 2012 | Computers & Internet
I would like to print some color pictures in black & white but I cant get it to do it. Any ideas
The black ink produces dark images while color ink produces multicoloered images. Once pictures that appear in color on the computers word documents are dispensed for printing, the color ink makes possible requests. It is impossible to request black charaters from colored ink on the printer.
Feb 04, 2011 | Lexmark X4580 InkJet Printer
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
My HP Photosmart 8150 has started printing color
You may have a colour management problem. Your monitor may need to be recalibrated from the software you are using to print your images. Your printer too may need to be sorted by calibaration too.
Jun 13, 2009 | HP Photosmart 8150 InkJet Printer
Printer is printer light and havin color problems
You can either change the image darkness level on the printer or through the printer drivers.
on the 525 control panel, you can go to the setup menu, and search through it until you see image darkness, select it, and change the values, go up or down by 10 points at a time.
in the printer drivers, go to printing preferences, and there is a tab that
will have image darkness in it.
Jan 21, 2009 | Fargo DTC525 ID Card Printer
Color transparencies are dark & poor color
Nice printer.. Hope this will give hints. Considering transparency papers, please try another batch of or a piece of transparency paper. Try to adjust also the graphics preferences (dark to light) aside from transparency paper selection. Have a nice day.
Best regards,
Rosener Guyano
Feb 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
Image problems
Sounds like your PCU is worn out. Try replacing it and see how you get on.
Jan 10, 2008 | Epson Aculaser C1100 Printer
OKI C5200n Laser Printer Logo
73 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
