Question about Dishwashers
Whirlpool du1055xtss3 not working
My Whirlpool DU1055XTSS3 hasn't been working for a couple of years now, and I'd like to stop hand washing all my dishes. I'm not sure what happened when it first stopped working, as I wasn't there, but I noticed not long ago that the Pots & Pans light was constantly flashing. I googled that today and found that I should press Hi-Temp Wash, Heated Dry, Hi-Temp Wash, Heated Dry, Cancel. After doing so, the Normal light started flashing non-stop along with the Pots & Pans light. Any insight would help me find what parts I might need to look for so my dad can help me get it fixed.
  • 35 Answers
I dont know if this indicates a malfunction or not. One user manual may cover several years while many modifications can take place. Ask yourself if any other part of the process can contribute to this. You have electricity to the control board or it will not flash these display indicators.
Is the water on?
Is the waterline kinked under or behind the machine?
Is it connected to hot water? A heater raises the hot water quickly but cold water takes alot longer to reach operating temp. Since the hottest program id pots and pans, this may indicate the heater is bad but since you were able to change the display to pp and normal I think you entered into a controls sequence that technicians can do to make changes to some parameters like temperature setting or water hardness. See if you can get a whirlpool tech to break the grip on his service manual and send you a page by email. Good luck.
Posted on Apr 24, 2013
Whirlpool DU1055xtss3 It washes but it seems that the drain pump doesn't stop even if no more water inside. End up pushing cancel Twice or pump just continues. Don't know if full wash cycle finished
Paul Lvesque, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Paul Lvesque), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool Washing Machines
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Washer control humming
it's always worth replacing the brushes - pattern one's are cheap at around 20 quid so it's just about the cheapest thing to try and washing machines do all mannor of crazy things you wouldn't think were related - like not draining (the water does still drain out but when it hasn't spun properly the clothes are still full of water for instance) worn brushes have a differing effect on difrent washing cycles. the other thing to suspect is the controller -but these are so expensive you can nearly always buy a cheap washing machine for less
Oct 02, 2012 | Whirlpool Washing Machines
Whirlpool DU1055XTSS3 Mydishwasher shut down in the middle of it cycle, like it blew a fuse. But the power to it works. What could be wrong with it?
Your pretty much on track when ya say that maybe a fuse blew. Clipped onto the control board is a fuse, This tip i wrote will show ya where that fuse is and how to check it.
http://www.fixya.com/support/r10341846-will
GENE
Sep 14, 2011 | Whirlpool Dishwashers
My washing machine (Whirlpool) stopped working. As it was working, it was making a noise that I can't really describe. Later on it stopped working altogether, now it only makes a buzzing noise. What is...
Normally it is the gearbox that making that noise, try turning the drum by hand for the full 360 degrees. if it wont turn then the gearbox is out of order and needs to be replaced
Dec 12, 2010 | Whirlpool LSR5132PQ Top Load Washer
I have a two speed automatic whirlpool washing machine
It sounds like your motor coupling has broken. Normally the older the machine gets,the more wear and tear on the coupling. Order the coupling as per the model and gain access to the main motor. remove both clips holding motor then pull off broken pieces then install new kit.(easy to see how). Reinstall motor and retry. Done.
May 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not work when it reaches at rinse
The part your looking for is called a lid switch, however you have to take the case off of the washer to replace it
Dec 16, 2008 | Whirlpool LSR5132PQ Top Load Washer
Dishwashers Logo
134 people viewed this question
Top Dishwashers Experts
