Question about Dell Dimension 3000 PC Desktop
I get a blue screen that says driver 1 not found
  • 81 Answers
Was anything recently updated on your machine either through Windows Update or manually installing a driver? If so, press F8 prior to the Windows splash screen and see if you can log into Safe Mode. Safe Mode will load windows with the least amount of drivers needed. If you are able to do this, go to Start, Programs, Accessories, System Tools, System Restore. Select a date to restore the machine from when it was working. Don't worry, you can go forward again or back further if you are unsuccessful.
Posted on Mar 13, 2009
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
Unable install windows xp . blue screen www.hardware-Update.com message Compaq
Sup guys i found the cure to this horroble blue screen death for this N610c. Ok i called hp and they wanted $69.99 for tech support well just imagine what i told them to do lol. Anyway i did my research and guess what i found out. That the updated driver is made to screw up your connection so that you have to call tech support and they can steal your money.
Im a computer technician since 1990 and what i discover was that beautiful driver that works here is a list of drivers that cannot be used on the Evo N610C because it causes conflits that no one can fix i know for sure.
List of the no no drivers are:
These drivers will make your screen go from windows to BLUE.
ap29156
sp28252
sp29156
Here is how i fixed the problem i deleted everything that had to do with LANMultiport drivers every single one then i searched my laptop to remove the rest of the lost files.
Once that was done the i installed this driver (sp23031)
Once that was installed and the puter rebboted the wifi card found my wireless connection and asked me to input my Network Key and walla it works great now without any problems.
Im using windows XP Home i just bought memory cause im installing windows 7 32 bit.
Finally the key is this driver (sp23031) for both home and pro eddition.
Here is the link to download your driver:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=hb-13082-1&lc=en&cc=fr&dlc=en&os=228&product=235687&lang=en
It works!
Dec 08, 2010 | HP Compaq Evo n610c Notebook
Laptop comes up with blue screen and basesdued 32 was not found
I thin you get driver error.
Why not fix blue screen with a registry tool.
Click here t i fix Blue screen.
Feb 04, 2010 | Toshiba Satellite A105 Notebook
I bought lenovo G550 last week. It came with Windows Vista. I want to install Windows XP on it. I have found that lenovo has driver for windows XP so that will make my life easy :-) But when I try to...
you are most likely getting a BSOD with a stop error code of 0x0000007B which is caused by the Windows XP CD that you are using doesn't have the SATA Hard Drive controller driver needed to recognize and utilize the hard drive. If Lenovo has XP drivers for this model then they should have a SATA driver (roughly 394k) that will need to be loaded FROM A FLOPPY DISKETTE during the boot to XP. (XP Requires the driver to either be slipstreamed into the CD or loaded from a floppy diskette. Trying to load the controller driver USB or a different CD will not work)
http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
Jan 11, 2010 | Computers & Internet
TEAC FD-05PUB Foppy causes blue screen
The driver should come with your computer. I have the same problem with a Thinkpad. Have you found a solution?
Oct 31, 2009 | Teac FD-05PUB External Floppy Drive
I got a blue screen telling that there is a problem with the file
Go to safe mode and uninstall the Graphics drivers and then restart and install the Nvidia Drivers again. Sometimes drivers get corrputed, so this things happens. if ur still getting this, then connect ur monitor directly on motherboards graphics connector and c whether u get this problem again, if ur not getting it means ur graphics card is not good.
Apr 20, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Game troubleshooting
Hi. memory dumps like that are mostly always hardware (or drivers) related. If you haven't changed any drivers recently then it's probably hardware. My recommendation would be : 1) In the startup option of Windows (right click My Computer, advanced), disabled the automatic reboot upon memory dump
2) Next time you have a blue screen , identify the DLL or SYS file in the message. if it's always the same element that crashes then you found your problem. Google the driver name and see what is the problem. If you see almost random DLL or SYS files in your blue screen then you have an overheating issue (90% of the time it's the reason) or a simple hardware failure. (pain in the a** but these things happen) also, that doesn't mean the data is gone, but chances are if you can't boot at all ever again with the laptop you'll have to hook it's drive as a slave on another computer and get your data back. BUT keep in mind that the problem you are describing is NOT a HD issue or you would get the typical "NO HDD detected" or "No bootable OS found" post post-test issue. hope that helps !
Feb 22, 2008 | Computers & Internet
Bushnell camera 111025
i need soft wear for bushnel 111025
Dec 01, 2006 | Bushnell ImageView 111025 Binocular
Dell Dimension 3000 PC Desktop Logo
52 people viewed this question
Alun Cox
