Question about HP LaserJet Pro CM1415fnw Color Multifunction Printer
Adf not working
Doesn't see paper in adf
2 Suggested Answers
DotRat
  • 146 Answers
SOURCE: The ADF on the LAserjet
Behind the hinge is a plug for the ADF. Shut down the machine and try reseating that plug.
Posted on Jul 11, 2011
How to fix the ADF problem, when it not copying
what is problem of adf?
Is adf dosen't get paper in? or doesn't scan?
Sep 17, 2012 | Ricoh Aficio 2022 Black and White Copier
1350 toshiba copier copy gets stuck
You need to clean the feed rollers for all your trays and for your document feeder or adf. If that doesn't work then replace them. But before you do that try checking if there is any paper, ripped or otherwise blocking paper path and removie it. It may just be that simple.
TOSHIBA BD 1350 SUPPLIES
Sep 12, 2012 | Toshiba T1350 T-1350 Compatible Copier...
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
Need user manual and software for a HP ScanJet 4p scanner
HI...................
HP ScanJet 4p Scanners - How to Use the Automatic Document Feeder (ADF) gtabseps.gif
gtabblt.gif Tips for Using gtabblt.gif Step 1 - Load the Paper gtabblt.gif Step 2 - Scan the Document gtabblt.gif To Scan a Single Page gtabseps.gif Tips for Using
  • Remove any paper from the copyboard glass before using the ADF.
  • Straighten any curls or wrinkles from documents before putting them on the document tray. If this is not possible, do not scan these documents using the ADF. Instead, use the copyboard glass or make a photocopy of the documents and scan the photocopies.
  • Remove staples, paper clips, and any other materials from documents.
  • Avoid documents with tears, perforations, or punch holes.
  • Do not use the ADF to scan sheets of uncommon paper or other media, such as the following: - transparencies - gummed-backed paper - magazine pages - lightweight ("onionskin") carbons
  • For paper smaller than 5 inches (127 mm) by 7 inches (178 mm) or larger than 14 inches (356 mm) by 8.5 inches (216 mm), use the scanner glass instead of the ADF. Paper smaller than the minimum size may cause a paper jam.
  • For paper lighter than 16 lb bond (60 g/m sq) or heavier than 32 lb bond (120 g/m sq), use the scanner glass instead of the ADF.
  • Before scanning, always push the front of the ADF downward to the scanner to ensure that the magnetic latches are engaged.
Step 1 - Load the Paper Besides the instructions below, quick reference decals on the input tray and access hatch show the order of steps for paper loading.
  1. Turn on the scanner.
  2. Ensure the scanner's scanner glass is free of paper.
  3. Turn the green paper load lever into an upright and open position. Refer to decal number 1 located on the ADF access hatch.
  4. Put the top end of the paper stack face up on the input tray. Refer to decal number 2 and pointer arrows on the ADF input tray.
  5. Push the paper stack up against the green document guide and slide it right against the green registration stop, which is in the middle of the paper load window.
  6. Turn the green paper load lever 45 degrees into the closed position. This will secure the paper stack. Refer to decal number 3 on the ADF access hatch. The ADF is now loaded and ready for scanning.
Step 2 - Scan the Document The ADF works with many software packages that are compatible with the HP ScanJet color scanners. To scan a document, refer to the user's manual of the software package being used. To Scan a Single Page To scan a single page while the ADF is installed on the scanner, do the following.
  1. Remove any pages from the ADF input tray.
  2. Raise the ADF.
  3. Place the page on the scanner's copyboard glass.
  4. Lower the ADF all the way and do the scan.
  • LINK OF THE USER MANUAL IS GIVEN BELOW.............
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=25293&prodTypeId=15179&objectID=bps01187
  • LINK OF THE DRIVER IS GIVEN BELOW................
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=25293
Sep 23, 2011 | HP Office Equipment & Supplies
When the printed paper comes out of the printer, there is a white line down the middle where the ink doesn't get on the paper Canon MX310
I presume this happens when you are copying and not just printing from the PC. If so then you probably have tippex on the scanner glass. open the scanner cover and you will see two glasses. the left one is for the adf and the larger one on the right is for the flatbed. I bet you have tippex or something white laying on one of the glasses. To prove this all you need to do is make a copy from the adf and make a copy from the flatbed. The adf one will probably have the white line and the flatbed will not.
Simples...
Jun 30, 2011 | Canon PIXMA MX310 All-In-One Printer
Why is there a line on the left side of my copy when I use the ADF on my Canon Image Clas D1150? It does not do it when the flatbed is used. Please help. Thanks, Joann
When lines appear on copies of documents fed through the ADF, it typically means that there is some kind of dirt or foreign material on the glass that the document passes over. A different window is used when scanning from the ADF as opposed to the flatbed. The flatbed window is large, often much larger than a standard sheet of paper. The ADF window, on the other hand, is small and slender. It doesn't need to be large because the document moves over it (as opposed to the flatbed, where the document is stationary while the scanner moves under it).
The ADF window is usually situated next to the flatbed glass on the side of the scanner where the ADF takes in the paper. Open the scanner lid (as though you were going to make a copy on the flatbed) and find the slender piece of glass just under where the ADF would be when the lid is closed. Once you've located the ADF glass, use a mild glass cleaner and a lint-free cloth to gently clean the surface of the glass. If you are able to see the foreign material, you can remove it by hand, but be sure to clean the glass thoroughly afterwards, as fingerprints can also cause poor quality copies.
After the glass has been cleaned, test the ADF copy function and make sure the line has disappeared. If it has not, you may need to remove the slender glass and clean the underside (though this is almost never required, as the underside is protected from environmental debris).
If you find this solution helpful, please leave a positive rating!
Jun 20, 2011 | Canon imageCLASS D1150 All-In-One Laser...
ImageRunner 1023iF auto-feeder stops mid-way through document. Pick-up and feed Wheel continues to spin for a moment, then stops and gives "Check Document" error. I have fed a card through the...
It can be the problem in sensor flapper on ADF tray ( small nose that is pointing out ). Maybe it doesn't works fine or in the middle of the copy from adf the paper is too far away from the sensor.
Also can be the problem of ADF pickup clutch or You are using unappropriate paper type- try with normal A4 80g/m as original to copy from adf.
Hope that something of this helps You!
Jun 02, 2011 | Canon imageRUNNER 1023iF Black and White...
Canon Color imageRUNNER C2550 legal size copying only works with single pages placed on the glass. Auto feeder ends up with image off center
when you making the copies, you MUST adjust the paper guides on adf/dadf. They are gray plastics left and right from original and can be moved to each other. They guide the paper rightly in adf/dadf.
If these doesn't helps, please describe what happens when dadf pulls the paper inside.
Apr 21, 2011 | Canon imageRUNNER C2550 Color Copier
HP LaserJet Pro CM1415fnw Color Multifunction Printer Logo
552 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
