Question about Ricoh Office Equipment & Supplies
RICOH FT 4615
Hi,I have a Ricoh Copiers FT 4615 .I have a problem with it . After 50 copies it make over.
  • 990 Answers
SOURCE: Error 52 on ricoh FT3213.
error code 52 on ricoh ft3213, that's mean heating element burn out , such as heater lamp, thermister , thermo fuse.
Posted on Dec 10, 2008
jaylex
  • 417 Answers
SOURCE: Ricoh ft 3213 printing problem
Is it only when you use the top feeder? Check by placing an original on the glass and copying if the same fault then there are three possibilities
  1. Optics Dirty (Dust on the copying mirrors) Remove glass and clean the mirrors on the scan unit also remove the lens cover and clean the mirrors under there replace lens cover clean glass and refit. (Do Not remove any mirrors you can clean them in there place and use a glass cleaning solution)
  2. Toner Waste and drum cleaning unit full. Open front cover and split machine as to remove jam not touching the drum (Large Cylinder ) check there is no banding on there. IF so to the left of drum there is a unit that contains the cleaning blade and fills with waste toner remove vacuum out waste toner check that cleaning blade ok and reinstall. Close and check machine if ok then great if not could be fault number 3 or that the cleaning blade is worn and need replacing.
  3. The fuser section (Heat section) While the machine is split look at the bottom left you will see a Orange unit this is the fuser section that houses the heat roller which welds the toner to the page. Check that the top roller is OK that there is no toner stuck on it and the Teflon coating is even. If not then the fuser will need replacing and as you said that you are missing text the most likely faults are going to be the fuser or the drum or the drum cleaning blade.
I hope this helps you
Thanks J
Posted on Jan 19, 2008
Cogz
  • 1326 Answers
SOURCE: ricoh ft 4618
Did you run the copier with out adding toner for awhile? If so, it is going to have to catch up with the toner level it had before or it may need a developer change. The toner level may be to low to regain it's amout of toner again. It may be a coastly venture with running the copier with out toner.. Good Luck...
Posted on Apr 30, 2008
NALDZ
  • 38 Answers
SOURCE: User manual for Ricoh FT 4427
I WILL GIVE YOU A MANUAL RICOH FT 4427 BUT YOU NEED TO PAY 100 US DOLLAR. EMAIL panlaqui08@yahoo.com.ph
Posted on May 07, 2008
fotobean
  • 103 Answers
SOURCE: On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you: http://www.copier-help.com/copier-help/
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Posted on Dec 11, 2008
Hi. I have a ricoh ft 4615. Heating is ok, gears moves as normal, each n every function is working but the print page is blank and displays U6. What might be the problem?
Try this:
Turn off the auto density
Go to manual density and adjust to the middle 50%
Try to run again and check your results
If none - you have to clean all the optics
Try again - if you don't get results there is a possible problem with the lamp/scanner system which usually requires someone making adjustments to one of the control boards.
Which brings you to contacting Ricoh for support - they are usually pretty good helping over the phone.
Ricoh's support and download link is below, if this doesn't work scroll to the bottom and click on contact us.
Support and Downloads
Best Wishes,
Joe
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_7bbaa7a1174e0903
Aug 25, 2016 | Ricoh Office Equipment & Supplies
RICOH FT 4615,ANALOG ERROR 54. wHAT DOES IT MEAN?
first check if there are any soot of toner inside the fuser,you can either replace the whole fuser assembly or fuser thermofuse/thermister to solve your problem
Nov 19, 2014 | Ricoh Office Equipment & Supplies
Ricoh ft 4022 photocopy machine displaying error code E-3.
cleaning requird clean properly with any quality cleaner then rty
May 17, 2012 | Pyle Office Equipment & Supplies
You can smear the print by touching it on the copies you make. The toner is not being fixed to the paper.
please check your fuser/fixing unit if it is ok or heating & pls specify your copier model ei" RICOH FT ____ RICOH AFICIO ____
Nov 24, 2010 | Savin Office Equipment & Supplies
Ricoh ft 5832 not print
Please describe your problem.You make one copies and not god?
Aug 15, 2010 | Ricoh FT5832 Copier
How do i clean a ricoh ft 4527 copy machine
start with the optics, corona wires, use the vacume cleaner, alcohol, water,...
Jan 05, 2010 | Ricoh CL4000DN Laser Printer
Bleda kopja i posle zamene bubnja i developera.na ricohu FT 4615
Please in the english or in the francaise or ungarische for help .
Nov 12, 2009 | Ricoh Office Equipment & Supplies
Ft 4415 ricoh flahing the magnigication indicator display
That means the machine is due for preventive maintenence, or PM. There is an internal counter that keeps track of the number of copies made. At a preset count, this indicator flashes. Kind of like "it's time for an oil change"
Aug 24, 2009 | Ricoh Office Equipment & Supplies
Ricoh FT 4015 too dark
Depends how many copies are in it. The PCU goes at about 60,000 prints its ordered as a supply. This is the heart of the machine. Lastly would be the fuser. -Carl
Jul 10, 2009 | Ricoh Office Equipment & Supplies
76 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
