Question about Compaq Presario 4640 (311300-003) PC Desktop
Need to change battery in compaq presario 4640
I have to reset the clock every time i turn on computer. it reverts back to 1997. works fine after reset.
    Scholar:
  • 77 Answers
Unfortunately, most manufacturers will not list the exact type and model of your CMOS (Motherboard) battery; therefore, you will need to open up your computer, locate the battery on your motherboard, and record the information about it such as voltage, chemistry, wiring, and packaging. If possible, remove the battery and take it to the location you plan on purchasing a new battery from.You may be able to find replacement batteries at a nearby electronic store like Radio Shack, or online via a Google search.
Posted on Mar 12, 2009
Compaq Presario CQ56-100SJ [XL580EAR] The clock keeps changing. I set the time, the timezone was already selected but everytime I look down, it's changed. After shutting down, it seems the time...
Assuming you don't have a virus, the laptop's internal (CMOS) battery may be bad. Apart from keeping the time current, it holds onto your machines bootlog. If the machine starts up in Safe Mode, it would likely be the CMOS battery that's bad.
Oct 18, 2011 | Compaq Presario CQ56-115DX Laptop
Seems the clock on my desktop compaq computer is running very slow. Where should look??
If your change your computer clock to fix it by double clicking the clock in the lower right of the screen. You turn the pc off and the clock is wrong or over time its wrong you may have a few things to look at
first check if the time zone (same way you look at the clock to change it buyt select time zone settings) to see if that is correct. If that is then the first thing is to purchase a new CMOS battery from a store liek walmart. These batteries are 1-4 $ depending where you get them and the quality. You can open the computer up and look for a silver battery about the size of a quarter. Remove it carefully while the pc is OFF. take it to a store and buy the new one then replace it.
Jan 18, 2011 | AMD Compaq Presario Desktop w/ Sempron...
Trying to install intel 333mhz from same "era" ('98) that works fine in another computer. but in 4640, it hangs at "entering setup" screen
Check the machine to make sure if has a 333mhz operation level,,, and not like a 133 mhz. You can tell this on the model tag that shows the serial number and operation info.
Oct 10, 2009 | Compaq Presario 4640 (311300-003) PC...
Compaq Presario cq50 will not power up.
try resetting the bios (by removing the battery normally in ram area)
Sep 22, 2009 | Compaq Presario Notebook
Save to disk file not found run ph disk for info
the cmos is under the aluminum of the keyboard try to remove it carefully its too easy
Jul 16, 2009 | Compaq Presario 1275 Notebook
Date keeps reverting to 10/08 and clock won't keep time
i donno much........ may be ur comp inbuilt[battery used 4 time setting] battery would hav run out....... i think so
May 11, 2009 | Compaq Presario 1275 Notebook
I've got a compaq presario 1245 laptop. On booting it gives me a black screen with "Error 0270 Real Time Clock Error" I can get into the Setup and boot screens (F1 & F10) but any changes (reset date/time...
hi
you will need to open your computer and look inside. if you are not sure take to a repair centre, the battery is on the motherboard, thats why you need to take really if you are going to be doing it. But i would advised to get a IT guy to do it for you. once its taken out you need to replace it with a new one.
Mar 25, 2009 | Compaq Presario 1275 Notebook
Time troubles
Your BIOS battery might be down. Becoz your board clock needs power from the board battery. So changing the battery on board will fix your problem.
Thanks
Iqbal
Mar 29, 2008 | Compaq Presario Notebook
Compaq Presario 4640 (311300-003) PC Desktop Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
