Question about Insignia Digital-to-Analog Converter for Analog TVs
Digital convertor box, picture breaking up
Have hooked up the digital convertor box and have a very good picture. But every now and then the picture breaks up. All connections are tight. thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Need stronger connection or TV roof antenna.
Posted on Mar 25, 2009
Can I hook the converter box up to a XBox360
sure but it will not do you any good the convertor box only works to convert old analog signals to digital ones
May 12, 2015 | Audio Players & Recorders
I need the code for my coby converter box so that I can use my universal remote
Try these codes.
0622 0632 0629 0621 ................. 0623 0576 0586 0616 0613
....... 0630 0634 0636 0638 0641 0652
....... 0653 0657 0659 0607 0619 0641
Apr 23, 2012 | Televison & Video
No sound on sony tv
Your set may have a choice of audio sources and outputs in the basic (initial) setup since it is not uncommon to mute the internal speakers and get your sound from a home theatre system or receiver. Also, if you are using S-video connectors between converter and set, there is no sound path, this is video only, and you will have to add a couple of cables, likely with RCA connectors, between the two.
For reference: Audio cables: Red=right channel, White=left.
Sep 06, 2009 | Insignia Digital-to-Analog Converter for...
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Is this tv able to use the convertor box to get digital signals?
Here is the manual: http://www.symphonic.us/pdf/om/SC313D.pdf Follow the instructions for connecting a cable box to connect your converter box. Front panel buttons can be used to make menu selections if you do not have a remote.
Jul 12, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
Can you tell me if my toshiba 20af44 is digital? Will I need a digital converter???
if the tv has a cable ready hook up then it can produce digital the trick is if your tv have satellite or a cable service then you don't need the convertor box but if you don't have none of these services then you will need a convertor box and if you have service provider and the service gets cancelled then you will need the convertor box
Dec 01, 2008 | Toshiba 20AF44 20" TV
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Insignia Digital-to-Analog Converter for Analog TVs Logo
386 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
