Question about JVC AV-32D305 32" TV
JVC AV-32730 36" picture problem..
JVC AV-32730 36"... the tv turns on fine, but after 5 - 30 min or so, "sometimes" the picture all of a sudden go's black. it makes a weird "zzzt" sound when the picture shuts off. Sometimes, it comes back on after a while, sometimes it does'nt. giving the back of the tv a whack sometimes gets the picture to come back on, sometimes it does'nt. Is it worth fixing ?
  • 398 Answers
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Posted on Aug 05, 2007
JVC 32" D series TV is suddenly black and white
Wow that's interesting, was there anybody watching your home while you were gone? There is a possibility that someone simply turned down the color level with the color control? Check that first. It's an unusual symptom. With composite video, component video or HDMI it's not usually possible to experience that defect. Since the color (chrominance signal) is usually inseparable from the luminance (black and white signal) I would check the color setting first. Other wise your set has become unable to detect that color signal... I bet it's a setting rather than a defect.
Happy Viewing
Zashiban
Jun 28, 2010 | JVC AV-32260 32" TV
My tv turns on fine after a few min the picture go's half black,if I whack the side the picture will come back on for a while and go back to half black again, could this tv be fixed?
The set has bad solder connections, specifically in the vertical output section. When you whack the set, the connections work for a while so the full picture comes back. Then, when they open up again, you're back to black. A service technician with a soldering iron could fix this easily, and the cost would be far less than the price of a replacement.
Jan 31, 2010 | JVC AV-32D305 32" TV
I AM ON CABLE. MY JVC AV-36150 PICTURE IN FINE ON
You`re probably getting a on air channel which means that you have to check your cable connectors and splitter if you got any, switch with other sets if you can.
Nov 01, 2009 | JVC AV-36150 36" TV
JVC 52 " Rear Projection TV Blinking Lights and no Picture
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Jul 17, 2009 | JVC AV-56WP74 56" Rear Projection...
Our 32'' JVC TV model # AV-32030 has an obscured picture.
With the remote go to the Closed Caption menu and make sure it is turned off.
Let me know if this helps
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Apr 03, 2009 | JVC AV-32020 32" TV
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 07, 2009 | JVC AV-36950 TV
Blue screen
bad connection but where need tech.
Nov 27, 2008 | JVC AV-27D302 27" TV
JVC AV-56WP30 56 black screen blue light on no response
make sure your front panel lock in your menu is not lock if is then unlock it cause it will lock everything on the tv in front and can't move anything
Jul 15, 2008 | JVC AV-56WP30 56" Rear Projection...
Suddenly all of a sudden
I have a JVC AV48WPT4 48 Inches. Have perfect picture but fine retrace lines on the screen.
Can you tell me what could cause it?
Thank you.
Apr 21, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-32D305 32" TV Logo
181 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
