Question about HP OfficeJet 6110 All-In-One InkJet Printer
I am receiving use plain paper in printer error message
I have the plain paper in my all in one. Because of the error message, I am unable to align my printer cartridges. Can this problem be resolved or is time to replace the printer??
  • 60 Answers
I am having the same problem with my canon 1960.
Posted on Mar 12, 2009
I cant get the printer to align what should i do
IssueA Printer alignment failed error message displays on the product.SolutionFollow these steps to resolve the issue.
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Touch the Setup icon.
  3. Touch the down arrow button (c01093709.jpg) and select Tools.
  4. Touch the down arrow button (c01093709.jpg) and select Align Printer. The product calibrates, aligns the printhead, and prints an alignment page.
  5. Touch OK to close the message.
  6. Recycle or discard the alignment page.
CauseAn incorrect type of paper is loaded in the input tray. If colored paper or photo paper is loaded in the input tray when aligning the product, the alignment might fail.
Jul 21, 2011 | HP Photosmart D7460 Printer
Tip
Resolving the Paper Mismatch error on the HP allinone printer
Set the Paper Type settings to plain from the Printers properties window.
This will turn of the paper sensor on the Allinone and hence, you will not receive the error message again.
on Dec 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hi, I have a lexmark x7170 and keep getting an error message "unsupported cartridge". Help please!!
If you receive an error message that tells you that you have an unsupported cartridge, then you need to remove the cartridge. After installing the appropriate type of ink cartridge you should no longer receive the error message and you can then perform a print test.
Instruction on how avoid unsupprted cartridge message.
  1. Lift up the scanner unit (with the power on). The printer cartridge carrier will move to the top of the printer into the loading position.
  2. Press down on the lever above the cartridge and then raise the cartridge lid. Remove the cartridge and make sure the cartridge supports no more than four colors (cyan, yellow, magenta and black) and a speed of 22 parts per notation.
  3. Insert the compatible ink cartridge into the carrier and then lower the cartridge lid. Close the scanner unit, then make sure plain white paper is inserted into the paper loader.
  4. Press the "OK" button on the control panel and the unsupported cartridge message should be gone. Press the "Select" button and a test alignment page will print.
Nov 21, 2010 | Lexmark X7170 All-In-One InkJet Printer
"Unable to Print" error message
you need to check that no paper is jammed in the gears - even tiny little scraps can cause the machine to throw up an error message.
Mar 31, 2010 | Brother IntelliFAX 1840C Plain Paper...
CANNOT ALIGN CARTRIDGES
Press and hold the Enter button, and then press Menue.
Also visit
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00657#Bypass_Alignment
Jun 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Paper Mismatch
the paper type is probably not set to "plain" in the printers menu.
May 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
Error Message 5C00
4 times is usually Automatic print head alignment
Set a sheet of plain paper (A4 or letter) in the ASF.and adjust.
Jan 14, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Printer not working...
Press Enter and Menu simultaneously when align message is prompted on the All-in-One.
Dec 25, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Ben Johnson
