Question about GE WCVH6260FWW
Broken select cycle knob
How do I change out the select cycle knob. Does the knob come off or is the repair more complicated?
    President:
  • GE Master
  • 662 Answers
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Washer Timer Knob (part #3957821) - How To Replace
Posted on Apr 24, 2013
2 Suggested Answers
  • 130 Answers
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
Posted on May 03, 2009
Can't switch between different dryer selections
is the knob broken?pull off the knob and see if it's cracked.
Jan 13, 2014 | Dryers
We have a Hoover 550MA washing machine, it gets stuck in a cycle and will not complete washing unless we adjust the cycle knob. How can we fix this?
the cycle knob has many tongs with contacts inside of it and they got pitted or bent from turning it the wrong way. replace it or take apart and fix but is complicated but possible .
other than that there are relays under the motor that changes to spin and wash transmission cycle. one can manually push the relays with a screwdriver to test it.
Oct 04, 2013 | Computers & Internet
The knob to select the wash cycle just spins and will not catch so you can select a cycle. Is there and easy fix?
the sleeve , or flat portion of the handle inside has probably broken, replace it most service centers will carry the part
May 15, 2011 | Washing Machines
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
1-866-383-3933
May 03, 2009 | GE WWSR3090TWW
GE WASHER CYCLE SELECTION KNOB
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 24, 2009 | Kenmore 24032\24036 Top Load Washer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Speed Queen HD comercial washer
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
Mar 30, 2008 | Speed Queen AWS52NW Top Load Washer
Program selector know is broken
First thing i would do if it is not selecting a different cycle is take the knob off and check to if the inside of the knob is broken and hust turning on the shaft, other then that it proberly is electronic replacement.
Oct 27, 2007 | Miele Novotronic W1930 Top Load Washer
GE WCVH6260FWW Logo
87 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
