Question about Car Audio & Video
Clarion car radio output plug wiring
I have an old car radio Clarion Model #PN-9551L that I need either: the wiring of the plugs in the back; the color coding of the clarion wires; or a schematic in order to safely hook it up to 12 volts.
  • Anonymous Apr 18, 2009
    same problem I'm looking for the back plugs wiring diagram so I can change out the radio.
  • hambo13 May 03, 2009
    I am trying to take out the old Clarion C116 and install a unit with CD player. I need the wire color code for the Clarion so I can insert the wires into the male harness component. Thanks
2 Suggested Answers
  • 239 Answers
SOURCE: Clarion Model #PN-9881l plug wiring
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Posted on Aug 19, 2010
gopakumarg43
  • 72670 Answers
SOURCE: i need the power plug wire harness that u hook the speakers up
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Electro help
Posted on Jun 17, 2014
Clarion PN.9967H speaker wireing
need wiring diagram for Clarion pn:9967h car radio in 1998 Nissan frontier, right hand drive please
Nov 23, 2013 | Car Audio & Video
I have a 2005 pontiac grand am and cant seem to hook it up. the wire installation kit that advance auto parts sold me Metra autoworks stereo wire harness. the wire harness number is AT-WHGM3. The clarion...
Ok, relax. The purpose of the harness is to wire you radio to it, then be able to plug into the factory harness without cutting wires. Let's start from scratch. The harness you have should have all the wires you need IF you told the retailer all the specifications of your vehicle. Basically the harness should have a positive, negative, switched power, and speakers (4 sets). Speaker wires are generally grey, green, white, and purple. Constant power is red, switched power is yellow, and ground is black. However, you unit may have other wires coming off of it, such as remote turn on (usually blue), RCA outputs, and will have an antenna jack that you may need an adaptor for. Sometimes factory harnesses have two plugs. Sometimes they are not required for the radio to be functional (it may be the output and return for an external amplifier that you are currently bypassing). So follow the instructions on the package. Don't feel like you have to be stuck in your car to hook your radio to the harness either. Hope this helps.
Sep 03, 2011 | Clarion Car Audio & Video
Is it posible connect a Clarion cdc635 in the same
no every maker has their own plugs...you cant take a pioneer and hook up to a alpine using the same plugs,,,unless you splice into the wirse on the plug and find wich one is hot..ground..etc........
Feb 17, 2010 | Car Audio & Video
Subwoofer istalation into a clarion DXZ375MP stereo
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
Mar 11, 2009 | Clarion DXZ375MP CD Player
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Jan 11, 2009 | Clarion XA-311 Cassette Player
Clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Mar 18, 2008 | Clarion DB245 CD Player
Car Audio & Video Logo
914 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
