Question about Nintendo DS Lite Console
My Screen is Completely white
When i turn on the ds it fades over to start it up but it never loads and leave a white screen,how can i fix this problem?(i had like 7000 codes on it)
Has anyone played journey to the centre of the earth the part Im having trouble with is after the third bridge in crystel tunnel very annoying like tryed all week same thing down the hole !!!!!!!!!
Posted on Mar 14, 2009
My action replay just deleted everything i had how do i fix it
This has happened to me to, so don't worry! 1. You could hook it up to your computer and resync it there. 2. 1st, hold Select and Start at the same time, then turn the DS on. keep holding it until after the DS' top screen says "This product is not licensed or endorsed by Nintendo". Keep holding Start and Select until it fades a different shade of white, then wait for a second, then turn off the DS. Now try the AR.
Oct 16, 2010 | Video Game Consoles & Games
My Tetris DS game won't load. I get only a white screen.
i think that calls for a replacement game and a stress releaver
Dec 03, 2009 | THQ Tetris for DS
When i turn on my DS the top screen is blank then it turns white and stays like that, i don;t know what's wrong
If your booting to a GBA game, there us a setting in the machine BIOS to tells it to use the top or bottom screen. You can access it by taking out the games and booting the unit.
If your booting a DS game, it should display on both. If not, it is possible a wire has come loose on the display (or the screen went bad).
You can try and check for the wire yourself or take it to a repair shop. If you bought it recently call Nintendo.
Nov 01, 2009 | Nintendo DS Lite Console
Screen goes completely white when I try and play any game.
I am prettty sure you can not fix that or maybe your lamp inside the ds is broken im not expert on a ds but im pretty sure it cant be fixed
May 25, 2009 | Nintendo DS Lite Console
Screen stays red
If you mean the bottom screen, replace it. If you mean the top screen, replace it.
Apr 22, 2009 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
Dropped ds- bottom screen broken, completely white
Well you can try getting a replacement from the store or try sending it in to nintendo.I doubt you can fix it.
Sep 21, 2008 | Nintendo DS Console
Blank white screen
Try using some alcohol to clean the contacts of the card and leave some on and reinsert a few times - leave to evaporate and try again - sounds like dirty contacts!
Sep 16, 2008 | Nintendo DS Lite Console
Action replay
sorry to disappoint you but there is no way of fixing it, you should get a free replacement depending on how long you have had the card, ive had my action replay for over a year now and it works perfectly, the card you have is corrupted trust me try and get a replacement from your manufacturer.
Jul 21, 2008 | Nintendo DS Lite Console
Top Screen of DS has faded to white
if he dropped it then the bottom should not show up as well. the bottom screen you can play the older games plus get instructions for the new games. if they are both out then it is the motherboard. if it is top only, it is the lcd screen and you can get that replaced for about $45. find a place to fix it or send it to nintendo. thanks, connie
Jun 22, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
