Question about Acer Computers & Internet
Fault finding motherboard not on
  • Acer Master
  • 5,660 Answers
What! !O_O!
For a statement, such as, "Motherboard not on", you would be stating the motherboard either does not receive power, or the motherboard does not use the received power.
Primer:
You press the Power On button. The first chipset to receive power is the BIOS chipset. The Basic Input/Output System program is initialized.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor (CPU) on; and hands the computer over to the Operating System. (In this case a version of Microsoft Windows)
If the statement is the motherboard is not turning on, you are in effect stating the BIOS chipset is Not receiving power.
Diagnoses must start from the AC adapter (Charger) You need to know if the AC adapter is putting out the correct Voltage. Also while testing have an assistant, gently wiggle the cable FROM AC adapter TO laptop; and power cord TO AC adapter. Any fluctuation in the reading, means a broken wire.
AC adapter proves to be good, the diagnoses goes to the DC Power Jack. The DC Power Jack is the jack on the laptop, that the AC adapter plugs into. (DC_IN)
AC adapter removed, Battery removed; a small instrument is used to see if you can gently move the DC Power Jack. ANY perceptible movement means a bad DC Power Jack -> Replace.
DC Power Jack checks out OK, then the problem will most likely be the Power MOSFET's on the motherboard. They determine if the Battery is to receive a trickle charge, or full charge. Also determines if the laptop is to run off of the Battery, or just the AC adapter.
Using the HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's; as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
I can give a lot more, than the generic information above, if I had the Model Number of the Acer laptop. This is on the Bottom of the laptop. Post back in a Comment.
Regards,
joecoolvette
Posted on Apr 23, 2013
  • joecoolvette
    joecoolvette Apr 23, 2013
    Love it when a website is undergoing changes. Posting direct link again,http://mayohardware.blogspot.com/2010/04...
Fault finding
Replace the motherboard. Or give us a description of the problem, we may be able to give you some information on how to fix it.
Oct 14, 2013 | EliteGroup Computers & Internet
KARBONN 550 INSART SIM
Possible fault in the motherboard. All you can do is to clean the SIM contacts on the board and make sure that the SIM goes in tightly . If so and if the phone does not respond you have faults in the motherboard which can be expensive and require a chip level fault finding.
Sep 26, 2011 | LG CU500 Cellular Phone
Computer monitors led flashing green and no signal to my pc
to start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitoror computer fault.if it is computer fault and no video signal ,then test
-video cable
-video adapter on pc (sometimes integrated on motherboard).
-motherboard
Aug 16, 2011 | Computers & Internet
How can i change the boot media before format?
Hi
Directly go to BIOS and there u can see the option to change the boot media. In mercury board there will be an option like advanced motherboard features . By clicking on that u can change the boot media
Thank u
Please rate me as it wil cost u just one click
Dont find a fault, find a remedy-Henry Ford
Oct 26, 2009 | Mercury P4VM800M7 Motherboard
Where can buy Acer 4520 AMD motherboard, as when I starts my laptop power comes and goes immediately. expert advised motherboard defected and needs to be replaced.
Firstly before replacing the motherboard please check whether the battery is working perfectly. I dont beilve its the problem of the motherboard and even if its the case other than battery it would be CMOS battery trouble . So check that stuff before directly going for the motherboard replacement
Thank u
Oct 26, 2009 | Acer Aspire One PC Notebook
CNM MiniBook (same as Elonex OneT, Alpha 400 etc.) Wont Charge
It's a motherboard issue. There is a component or components that have gone out.
You need to replace the board. Most techs can't fix the problem itself, so a swap is in order.
Jun 15, 2009 | Computers & Internet
Computer wont turn on trys to but keeps restarting itself
83 - 96 - 9E (for a **** second)-9F
on the post code definition display on the mobo.
When it hits 9E it has shutdown and reads 9F when totally powered off.
I have read on other newsgroups that the power supply might be at fault
I took this from an overclocking forum, I hope it helps
Dec 20, 2008 | Abit AV8 Motherboard
Abit SG-80 Rev 1.0 Motherboard beep codes
type in beep codes into search engine find the ones for your M/board it usually means you have a fault on it try changing video card or ram
Jul 30, 2008 | Mercury P4VM800M7 Motherboard
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
