Question about Radio Communications
Require manual and frequency
Require manual for frequency and set uo
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model scanner?
Posted on Apr 23, 2013
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
Icom v-68 no transmit no recieve
To help you resolve the issues with your radio, much more info is required. What frequencies are programmed in your unit, is it VHF or UHF, this is required before we can begin. Do you know if the radio has frequencies programmed in the set, if not, that would be the obvious reason why you are not able to use the set.
Be that as it may, i do have a solution, but bear in mind what I have stated re: info required.
Join yahoo group SPECIFIC to your radio Make/Model, the technicians there will require as much info from you as possible regarding your set, so than can give you the solution to the problem, plus you can download manuals, schematics and software and all this is completely FREE.
I hope I have been helpful.
Best regards,
Peter
Mar 06, 2013 | Icom Radio Communications
How do I program a yaesu ft-270?
I will be working from the online version of the manual located here. It may or may not be the same as your printed manual included with the radio - so you might want to download this copy.
First, let's set the radio to automatically set up repeater input shift based on the published receive frequency. By default, the 270R will transmit 600Hz up or down as determined by the band plan. This feature is called ARS and can be disabled if desired. If it does not display a frequency 600Hz up or down from the receive frequency while transmitting, is has been disabled. Let's re-enable it by performing steps #1 thru #5 on page 19 of the manual. Once completed, the 270R will automatically shift the transmit frequency (to match the repeater input frequency) as shown in the top half of the "ARS-Repeater Subbands" graphic at the bottom of page 19. The bottom half shows the export version of the shifts and does not apply to USA versions. If you have "odd splits" (repeaters that have input frequencies that are non-standard ie: other than 600Hz; or shift up instead of down and vise-versa) you'll need to manually change these later as described in VHO Split Mode on page 21. Any repeater operating on 147.000Mhz may have a shift either UP or DOWN. As you can see in the graphic, 147.000 is between the (-) and (+) shift so it could be either direction. Double check to make sure the radio matches the shift that the particular 147.000Mhz repeater you wish to access requires.
Next, create a list of repeaters that you wish to save in memory (you can check online databases to obtain the most recent information). This list should include Name, Receive Frequency, any non-standard direction or value Shift (called "odd splits), Tone Type and Tone. The name should be 6 or less alpha-numerics in length and be something that helps you identify it . This could be the name of the repeater owner: "TIM, PETE, etc. ", the name of the club that runs it: "BARC, CMARA, etc.", the city or town it is in: "BOSTON, OAKLND, etc,". You might run into names that would create duplicates when there are more than 1 repeaters there in the same location. Boston has several 2M repeaters - naming them BOSTN1, BOSTN2, etc. may help you remember them, but it will be easier still to append the decimal portion of the frequency to remember - such as in the case of a Boston repeater on say, 146.030Mhz and one on 145.150. BOS030 and BOS150 would probably be easier than trying to remember which is BOSTN1 and which is BOSTN2. Placing the names in the 270R memory is the last thing done, so don't worry too much about a name for the 270R's display just yet.
Most repeaters use CTCSS for access. Some newer repeaters use DCS. Some require or even prefer that no tone be sent at all. CTCSS is an analog frequency and a DCS code is digital data. The repeater may require one or the other to be present to "wake up" and begin retransmitting your message. All you really need to know about these two systems is the you need to match both the tone type and the tone value to successfully activate the repeater. Set the radio to your desired default power output level. Tap the VFO button once to enter VFO mode (if not already in VFO mode).
Enter the repeater's receive frequency by twisting of the tuning dial (page 13) or by direct entry (page 14) via the keypad. When using the keypad, do not enter the leading "1" of the frequency - as all the frequencies that this radio can tune begin with "1" and can not be changed. With the repeater frequency displayed, next enter the CTCSS tone for the repeater as described on page 23. If the repeater uses DCS, follow the directions that begin 1/3 of the way down on page 24 instead. As far as "TONE" and "TONE SQ" are concerned, the difference can best be described in that a radio working on a repeater system benefits from use of TONE, and a radio working on in simplex operation (no repeaters) benefits from the use of TONE SQ. Since we're programming repeater frequencies, there's no need to select TONE SQ. If the repeater strips the tone from its output, your radio will remain silent if set for TONE SQ. TONE is a much better match for our needs. Remember, you must use the DIAL to select the CTCSS tone frequency or DCS Code. Unlike the repeater receive frequency, it is not possible to directly enter the tone frequency or code via the keypad.
At this point, the radio should be displaying the recieve repeater frequency. Since automatic repeater offset is enabled - the 600Hz offset frequency and direction are set. The tone type and value for this repeater frequency have just been set in the previous paragraphs as well. Now it is time to write all this information to the radio's memory. This is detailed 1/3 of the way down on page 29 under "Memory Storage". Once you have performed step 5 in Memory Storage for this first repeater, it says to repeat this same process. This means setting the next repeater's recieve frequency, tone type and tone value - just as you have done with the first.
Once you have made sure that you have unique names assigned and the other information above, you are ready to begin adding them into the 270R's memory. You can go back add names to be displayed instead of the frequency of the repeaters if desired. Page 31 details the procedure to assign an alpha numeric name to each memory location. Make sure that you are assigning the correct alpha-numeric to the repeater by checking the frequency from time to time - don't blindly add alpha-numerics to memory channels.
This is a very tedious process. Ham Radio Outlet offers Windows programming software and transfer cable by Yaesu called "ADMS-270" for $38.95. This package allows you to easily create many lists of memories on your Windows PC & keyboard that can be uploaded and downloaded "on the fly" I highly recommend this software - or any software that allows you to program the radio from a computer rather than the radio itself.
I hope this was helpful.
Nov 29, 2012 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
Why won't new screen come on when powered uo?
I can only guess from your question, but I think that your previous monitor had settings that the new one does not support.
  • Try to connect older one to the computer and lower the resolution and Frequency rate of the monitor from its properties menu like on the picture.
  • After that connect the new monitor. This should do the trick if the problem is in the unsupported settings.
If you can't see the initial bootup screen, then probably the problem is in your cable or video card. This usually can happen when using DVI output.
Nov 26, 2011 | eMachines Computers & Internet
To RESET all programs Frequencies on my IC-H16 portable radio.
You can download and review the manual for the Icom IC-H16/U16/U2 HT here. This radio is an Amateur Radio Service transceiver, and will require an FCC license to transmit. No license is required to monitor or listen to the radio. Keep in mind, the Amateur Radio Service is NOT part of "CB" or "FRS" radio services - neither of which require a license to transmit.
When you read the manual, you'll quickly see that there is no "reset" function available. There are only 16 memory locations, so you can simply lock out channels you no longer wish to monitor or you may program any valid frequency in the range supported by the radio. Doing this, in combination with setting the squelch or tone will prevent the radio from opening a particular frequency(s) when the corresponding memory location is scanned.
I hope this helps and good luck.
May 04, 2011 | Motorola GPS
I cant listen to the police
First, make sure that you have the correct frequency for your local police. You can find a comprehensive database of active frequencies in your area by visiting:
www.Reference.com
Program the frequency or frequencies using the instructions in the scanner's operating manual. and you should be all set. If you need the manual, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
NOTE: If the frequency database shows that your local police are using a trunked system, you will not be able to monitor them using the BC60XLT-1. Trunked systems require a trunking scanner. Many law enforcement agencies are also using digital systems for their communications. If that's the case in your area you'll need a scanner capable of monitoring APCO-25 digital transmissions.
Bill B.
Listening in since the 60's
Nov 13, 2010 | Uniden BC60XLT-1 Handheld Scanner
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
Wrong time on Emerson Smart Set clock
This is a problem with the clocks tuning crystal. Digital clocks have a crystal that is tuned to run at a certain frequency to keep the clock working correctly. These clocks have a problem with that crystal keeping the frequency locked at the correct working frequency. This problem will sometimes cause the clocks to run fast due to a running frequency higher than the regulated frequency and sometime slow due to a running frequency running lower than the regulated frequency. The only way to fix this problem is to either adjust the crystals frequency to the correct frequency and lock it. Or change the crystal. Both these types of service require tools and test equipment to fix the problem. This is usually best handled by a service center. The Emerson customer support telephone number is 1-800-898-9020. Give them the make and model number of your clock radio and ask them for assistance. I hope this information helps you with your problem.
Nov 18, 2008 | Emerson Smartset Clock Radio
How to program an old regency 1060 scanner
I'm not too sure about this particular model, but other Regency variations require you to push the "Manual" button, enter the channel number you want to set (usually 01-09 for single digits) and then enter the frequency you want. On some you may need to enter the frequency first and then the channel number.
Oct 11, 2008 | Uniden BC72XLT Handheld Scanner
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
