Question about Kenmore Dryers
Kenmore dryer model #41788042700
My dryer will run for about 5 minutes and then shut off. When it shuts off all of the lights above the start buttons flash quickly. I have tried unplugging the machine, but the problem still happens.
huuum
  • 750 Answers
SOURCE: KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Posted on Jan 23, 2009
  • 65 Answers
SOURCE: Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Posted on Jan 28, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Posted on Jul 27, 2009
SOURCE: My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Posted on Feb 24, 2010
Dryer will not start
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not start. I also see that when you press the start button, the lights above the Control button blink and your dryer beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not start: when I hit the start button, dryer beeps and lights blink above Control button
-Best Regards-
WP
might need a control broad if you know how to check it out ,if u still got the mannual that came with the dry it will have a troubleshooting page you can read it will help you out are calll a appliance repair man ok
Jun 10, 2017 | Kenmore Dryers
Hi more info. I posted wrong. my dryer is model 11079912990. ser # mj1607152. type ddot-nat-1206006, cv22. 120 volt, 60 hz. 22000 btu .27 inch wide kenmore gas dryer. The dryer would run for a few...
You could have a blown fuse because of a clogged vent or a bad thermistor. A thermistor is used by electronic controls to measure temp changes inside the dryer. If the sensor is open then the brain does not have a clue how hot the dryer is. So it shuts down. Repair clinic has an excellent thermistor replacement video.
Oct 25, 2013 | Sears Kenmore 7.3 cu. ft. Gas Dryer Model...
Kenmore dryer 11070882990 dryer runs for 3-5 minutes and shuts off
is the door popping open? check your door switch and actuator.
When you press the start button is there a delay/hum sound before it start. if yes it is a bad motor
can you start the unit back up after it dies or does it take a minute?
Aug 24, 2010 | Kenmore Dryers
I have a Kenmore Electric Dryer Model 417 Super Capacity w/Balanced Dry & Moisture sensor. When turned on, it runs 5-10 minutes & shuts down. The series of green lights over the pause/cancel button...
This is something your going to need a service tech for. The error is taking place within the control console itself and the console my need to be replaced.
Dec 14, 2009 | Dryers
Jun 21, 2009 | Dryers
Kenmore gas dryer model 97284100
The door latch is about $5. Replace it.
Any appliance parts store has them.
Mar 27, 2009 | Kenmore Dryers
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer model 417.84252500 runs but does not heat
Disconnect the plug. Disconnect the wires to the heater element. Using an ohm meter or test light,test the heater element to see if it is open. If it is open the meter needle will not move If a test light , it will not light.  If true then replace element.
Dec 14, 2008 | Kenmore 63942 Dryer
Dryers Logo
165 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
