Question about Imperial IFS40 Deep Fryer
Pilot light won't turn off
Hy, I turn on the fryer normally. The pilot light turn on ok and the burner too, but when I turn off the pilot at end of the day, the pilot light won't turn off like always.
    Master:
  • 563 Answers
Any parts been changed? valve might be wearing out.
Posted on Apr 23, 2013
Testimonial: "Thanks Chris, All parts are original, I have not changed any. I bought the fryer for a year and has been normal use."
I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
Jul 30, 2012 | Imperial IFS40 Deep Fryer
Burner problem
Hi there!
Check the incoming gas pressure.
Insufficient gas pressure will greatly affect the unit's efficiency.
Regards.
Apr 03, 2012 | Pitco Frialator 35CS Deep Fryer
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
Need to know where to light pilot
Normally, it's under the fryer, inside the door...The issue almost always is you have to press the button down long enough for the sensor to tell the fryer to light....There are 3 or 4 burners in the bottom of the frypot on top and under the fryer is the pilot to light these all up...Look for the gas valve, turn the gas valve to pilot, and press and hold it down, put flame to pilot and release button when flame is self standing... Then turn to on position. If you have other issues, call the Vulcan company themselves, and they will help you further.... Susan Restaurant Equipment Outlet, Cinc, Oh www.restaurantequipmentinc.com
Aug 20, 2011 | Vulcan EF3 Deep Fryer
Hello i have a J5 lincat fryer and the pilot stays alight but the burners won't connect (light) have replaced the thermostat and the thermo couple but still no joy any ideas on this not sure what to do...
Check if there is 500 to 750 millivolts across the thermopile wires; thermopile generates 500 to 750 millivolts if properly heated to energize pilot and main valve solenoids of the gas valve for pilot and main burner operation. If the voltage across the thermopile is good and all wiring connections are ok, I think you have to replace the gas valve.
Regards.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
45C- Flame and pilot went out during operation, Pilot won't relight.
If your pilot is a manual ignition model, make sure that the thermopile is clean (free of soot), it is the cylindrical piece of metal behind the pilot assembly which is heated by the pilot flame, a very small amount of voltage is generated by it to open pilot and main burner valves of gas valve.
Jun 03, 2011 | Pitco Frialator 45C Deep Fryer
Pilot light goes out when burner turned on
Replace the pilot generator. You are not getting the millivolts you need when you turn on the fryer.
Tom
May 28, 2010 | American Range AF45LP Deep Fryer
I cant find the way on how to light uo the friar.
If you have a pitco 35 fryer, all you need to do is have gas connected and turned on, rotate the know on the gas valve to the pilot position, depress the knob, while holding the knob down light the pilot, normally located in between the burner tubes in the middle of the front of the fryer, hold the knob for 60 seconds, when you release the pilot should remain on. If it does rotate the pilot know to the "on" position, from this point the thermostat should control the fryer. If your pilot does not stat lit, press the red button on the hi-limit to reset it, it could be tripped and this would cause the pilot to not hold. Hope this is helpful.
Mar 18, 2009 | Pitco Frialator 35CD Deep Fryer
Imperial fryer
If your pilot lights up but the main burner doesn't light up then you have a bad pilot sensor or gas valve
Sep 16, 2008 | Imperial IFS50 Deep Fryer
Imperial IFS40 Deep Fryer Logo
147 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
