Question about Makita 10" Compound Miter Saw LS1040
Makita 10" Compound Miter Saw LS1040 manual?
Hi. Does anyone know where on the 'net I can go for the manual for Makita 10" Compound Miter Saw LS1040? (I've looked). A friend gave me one, and after a look, I can't get blade lifted (power off). Wish I still had my old Delta sliding miter saw, but not in the budget at the moment. Thank you.
  • soozankrayg Mar 12, 2009
    Wow. Thank you! That was getting frustrating for awhile.
  • 8,197 Answers
I have been given a used 10'' benchtop
compound miter saw, but i dont know how to unlock it to lift the blade. can u help
Posted on Jan 12, 2011
Guard spring replace
springs are available from the manufacture spares places or from a hardware store. Any spring of the same size and length will do the job.
Mar 29, 2013 | Makita 10" Compound Miter Saw LS1040
I can not remove armature caseing from makita miter saw
The casing at the saw end will have an inside case that is bolted either from behind the gears or from the armature side by screws. This has to be undone to allow the bearing to separate from the case
Jan 16, 2013 | Makita 10" Compound Miter Saw LS1040
How do u unlock a 10'' benchtop compound miter saw
slightly push down on the handle, then look directly over the top at where swivel spring is either on the left or right side , there is going to be a pull pin, it will only pull out far enough for the handle to go up and down, its not suppose to come all the way out
Jan 12, 2011 | Makita 10" Compound Miter Saw LS1040
I have a Makita 10 inch compond mitre saw. My owners manual has been lost and I need the tables that show what degree to set the mitre and bevel for various degrees.
You can get it at Makita.com, type in yr modal number in the search bar, download a parts breakdown or a manual, if not u can order a new sticker from makita.
Jun 08, 2010 | Makita 10" Compound Miter Saw LS1040
The cut is not square on 45degree miter
Hello. First of all adjust your saw on straight cuts so that it is spot on 90 degrees. Then go to the 45 and test it again. Being off a tiny amount at 90 degrees is compounded when you go to 45 degrees.
Nov 19, 2009 | Makita 10" Compound Miter Saw LS1040
My makita sliding mitre saw is off a few degrees How do I adjust...non laser...10''
move the blade until it is square to the fence then loosen the screws on the table with the degree increments and set to zero.
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
How to lift blade on mikita 10 mitch saw
right side of saw is a spring loaded knob. push saw down and pull out knob - rotate knob 90 degrees.
Oct 14, 2009 | Makita 10" Compound Miter Saw LS1040
Need to re assemble trigger of ls1040 mitre saw, is there any instructions
go to MAKITA TOOLS.COM under benchtop on the menu select miter saws and your model number once in there there is a menu showing instruction manual, parts assembly and you can geta full print out diagram of how it should go together
May 03, 2009 | Makita 10" Compound Miter Saw LS1040
Makita 10" Compound Miter Saw LS1040 Logo
1,522 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
