Question about Bernina Sewing Machines
Bernina 830 Record-2 problems
Hello, I recently purchased a Bernina 830 Record.  I've opened it up and cleaned what I can and oiled the hook.   It seems to have 2 problems. Firstly, I cannot release the inner wheel on the handwheel when winding a bobbin on.  It is very tightly secured and will not budge.  The bobbin still winds, but annoyingly the needle shaft moves up and down at the same time. Secondly, when buttonholing, positions 1,2,3 + 4 are fine, but when I turn the knob to position 5, the top thread breaks and I notice that the left side of the needle seems to be shearing off slightly. any advice would be greatly received. Many thanks Caitlin
Blindbox1
  • 9 Answers
SOURCE: Bernina 830 stuck
Okay, my first take—because it fills bobbins "just fine"—is that the needle bar may be loose. You didn't specify what the service was for: was it just a clean and lube, or did you have a problem? Even with just a clean and lube, the needle-bar height may have needed adjusting, and the tech may not have tightened it securely. Does the needle bar move at all? even just a quick **** or two? If it acts like it is trying to move, but doesn't, that is probably the problem.
Now, here's the bad news (always seems to be some of that with these kinds of things, eh?): That needle-bar height is critical, and it's not something I can just tell you how to do here. The second bit of bad news is that the problem wasn't discovered for a year, so any service warranty is long expired, by now (unless the owner or manager of the store is your bosom bud, or, you are one of his/her best customers).
The good news is, if the shop is reputable, you could return it to them, explain what happened, and ask how much they would charge just to adjust and secure that needle bar (although the machine could probably use some more oil, by now—because it has just been sitting, which is harder on them than if you use them regularly). If they are like the shop I worked for, they will be glad to give you a slightly discounted rate to preserve their reputation, and hopefully, your business relationship with them. They may even throw some oil on it for the same price.
One more bit of good news, the Bernina 830 is one fine sewing machine. It is worth fixing, if any machine is.
Hope this is helpful, and happy sewing!
Ken
Posted on Feb 06, 2009
RickE1
  • 202 Answers
SOURCE: Bernina 830 won't zig zag, won't buttonhole, no decorative stitch
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps, I know it will.
Posted on Feb 13, 2009
SOURCE: Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Posted on Mar 14, 2009
  • 52 Answers
SOURCE: bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Posted on Jun 26, 2009
  • 13 Answers
SOURCE: old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Posted on Aug 29, 2009
What would cause a Bernina 830 Record to be sluggish and labored at low speed but run beautifully at high speed? Thank you.
Your beloved Bernina 830 Record needs a good cleaning and oiling. The old oil has solidified and is beginning to seize the machine. Continued use may burn out the motor. Also, other parts will begin to falter, ie the stitch selectors, the feed dogs, the needlebar... These old machines are great but they do require TLC to keep them happily purring.
Wheel on right side that controls the needle up and down is very tight...
Sep 07, 2017 | Bernina Sewing Machines
Needle threaded is stuck in up position will not return 830 bernina
Bernina 830 Record??? Or newer Bernina 830 computerized?
If it's a Record, could very well need a good cleaning and oiling. Older mechanical machines need periodic lube to keep them running smoothly and quietly.
Feb 11, 2017 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
My Bernina 830 sewing machine will not sew any of the decorative stitches.
Is this the vintage 830 record, or the new electronic model?
If it's the Record, flip the top open, and oil all metal-to-metal. Run for a full minute, oil again, and run another minute. It should start to work once the oil has been worked in.
Mar 05, 2015 | Bernina Sewing Machines
I Have a bernina 830 and the foot doesn't come down or up how do I get it working again?
Have you followed the maintence standards (oil schedule). If not
that may be the issue. A wild guess (at least this was the issue
recently with wife's older White machine. The foot lever was catching on the thread cutter device. Otherwise, perhaps a screw has come loose somewhere in the lever and or foot. Good luck. Double check your manual troubleshooter section.
Feb 26, 2015 | Bernina Sewing Machines
Bernina 830 Record foot pedal won't engage sewing unless I turn the hand wheel.
your motor is going out. time to replace or rebuild your motor. both are high skill and should be attempted by a professional. take it to your nearest bernina shop.
Feb 07, 2013 | Bernina Sewing Machines
How do i use the zigzag stitch on my bernina 830
Hi, open the top cover and if you watch what goes on inside from the top when you move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
Feb 01, 2009 | Bernina Artista 180
My machine Bernina 830 does not run.
Hi Rose Mary,
I'm assuming you are talking about the original Bernina 830 (their newest machine is also an 830!)
If you've not had your machine professionally serviced in awhile, it could be as simple as a good, thorough cleaning and adjusting. Your machine should be professionally serviced about every 1-2 years....not a bargain service that blows out the dust and puts oil on the hook, but a service that checks all the gears for wear, adjustments, hook timing, feed timing, grease for the gears (if required), removes lint build-up deep in the machine - very thorough.
There are various gears in the 830 that control these functions. It sounds as if one of the gears may be either broken or jammed. Unfortunately, unless you are trained in machine repair, this isn't something you should attempt. When gears are replaced or adjusted, generally the timing of the machine must be reset as well.
We would recommend that you take your Bernina to your nearest authorized Bernina dealer (they'll be trained on your specific machine and have easy access to any parts that may be needed).
If you do not know a dealer in your area, you can search on the Bernina website.
The original Bernina 830 was one of the greatest models Bernina has made and is well worth putting the money into keeping it running. Great machine!
Hope this helps narrow down what may be happening.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Nov 29, 2008 | Sewing Machines
Sewing Machines Logo
527 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
