Question about Vehicle Parts & Accessories
Ticking noise on engine
Hear a loud ticking noise when i turn it on and it wont go away.
  • 460 Answers
Sounds like the trimming chain. What kinda of car and year?
Posted on Apr 24, 2013
  • pelacas20 Apr 25, 2013
    2004 explorer v6.
Had ticking sound started up this am loud pop then rough running like there was no muffler
Ford Windstar Starting/Stalling Problems - Car Forums at Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Learn more about Ford Windstar at the Edmunds.com Car Forums! ... I tried to startmy van on a 15 degree morning - heard a loud bang and now it won't start. Battery ....The engine will crank, start run about 5 seconds then stop. ... I have a 2003 Ford Windstar, same problem,Ford is covering up the problem.
Why My Car Won't Start? - Reasons and Solutions
www.myautorepairadvice.com/car-wont-start.html
As a rough guideline, problems with the battery, alternator and starter are the most ...Before I even put the key into the ignition I hear a clicking noise on the right side ...started it and then it started making a loud clicking noise while I was driving it ..... i have a 2003 windstar ford it was clicking and wouldn't start had to get a ...
Rough Idle Engine Dies Loud Ticking!?! Please Help! - Ford Focus ...
www.focusfanatics.com/.../103146-rough-idle-engine-dies-loud-ticking-...
Nov 6, 2006 - Rough Idle Engine Dies Loud Ticking! ... down then dies and then i restart and it has no problems but the ticking continues PLEASE HELP ME ... Level Up0% Completed ... 2. my injectors are bad and the ticking sound is one of the injectors.... Another method is to turn the AM radio on to a place where there ...Missing: windstar
Jan 08, 2016 | 2003 Ford Windstar
02 Pomtiac Bonneville SSEI Help?
This sound like you have either delay on internal lubrication to tappets,most probably due to correct oil either change or viscosity.
In how many miles you do change the oil ? Just do an engine oil flush and a engine oil & filter change using also a viscosity improve and follow for a different engine behavior.
Nov 22, 2013 | Cars & Trucks
2003 impala LS making loud ticking noise on cold starts, subsides when warm
yes chevys 3.4 and 3.5 have common lifter noise, have you checked the oil level. I would a better oil ,and I put lucas oil treat in my customers cars after oil changes
Nov 11, 2012 | 2003 Chevrolet Impala
2005 chevy classic ticking noise check engine no start
timing chain could have jumped timing if you hear timing chain noise.
Dec 02, 2011 | 2005 Chevrolet Malibu
I HEAR TICKING IN THE ENGINE AND IM NOT SURE IF IT IS MY TIMING OF A LITTLE OR WHAT
The ticking is most likely to be the injectors. You will hear these prior to the engine starting when the ignition is at position two as the fuel pump builds pressure in the fuel line. If the ticking is loud and can be heard after the engine has started this could be a noisy cam shaft. Make sure your oil levels are OK and if the engine is running fine and pulling well do not become overly concerned about additional engine noises. If the engine starts to misbehave then that is the time to chase these noises down.
May 25, 2010 | Honda Accord Cars & Trucks
2006 BMW 3251 loud ticking sounds from engine
this is a very common issue with any of the bmws with n52 and n52k engine,as long as oil level is ok and is being changed regularly than than a "blleding proceedure" may solve this problem, when the engine has been running long enough that it is hot run the engine at idle to 4500 rpm for 10 to 12 min to start, if is still present after this attempt again.It has been said that this could take up to 30 min at longest.The reason for the ticking noise is a very tiny air gap in the hva and or lifters, try this and if does not work than the lifters should be replaced, although this noise doesnt really hinder the performance it does take away from driving such a nice car and having a loud noise come from the engine, good luck
Feb 17, 2010 | 2006 BMW 3 Series
Ticking Noise at Startup
Possibly a leaking hydraulic lifter. They can leak down while engine isn't running and then make a ticking noise for a while on startup. If it takes 10-15 minutes to go away, it is more likely to be a loose tappet which needs adjusting.
Aug 02, 2009 | 1995 Buick Riviera
Ticking engine
Have you checked the engine oil level recently?
May 17, 2009 | 2004 Land Rover FreeLander
ThenI start my engine it sounds like diesel and no power
how is the oil level and pressure?, how many miles on engine? is this a loud knock or rather a clatter/ticking noise? knock is engine rod or crankshaft bearings, clatter loud ticking is valve follower noise. how long before it (the noise) goes away?
Jan 20, 2009 | 2001 Audi A4
Vehicle Parts & Accessories Logo
65 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
