Question about Whirlpool MH7155XM Microwave Oven
Demensions of mh7155xm - Whirlpool MH7155XM Microwave Oven
Began making loud noise and not heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 18, 2010 | Whirlpool MH7155XM Microwave Oven
Microwave comes on but does not heat anything. Is 10 years old
Hello there:
If it It sounds normal,and seems to run ok but there's no heat When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the megatron or power inverter or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician. ok hope this helps best regards mike
Aug 30, 2010 | Whirlpool MH7155XM Microwave Oven
Whirlpool MH7140XFQ Fuse to Breaker Problem
There is absolutely no way to guess at the problem. You need to troubleshoot the circuitry with a meter to find the failing component
Oct 06, 2009 | Whirlpool MH7155XM Microwave Oven
How do I replace the fuse or reset the circuit on a Whirlpool Microwave Hood Combination Model MH7155xm.
remove the outer cover and its in a fuse holder on the right side of unit get the right amperage
Oct 01, 2009 | Whirlpool MH7155XM Microwave Oven
MH7140XFQ Fuse Amp
you need to look at the ends on your fuse and this will tell you the amperage you need to get for your particular unit,get them from a hardware store
Sep 22, 2009 | Whirlpool MH7155XM Microwave Oven
I have a whirlpool model MH7140XFQ and we got a guy to come and look at it and he said the Mag. tube and the circuit bars were broken. Which would be more expensive to change the broken things or just...
He is referring to the magnatron tube which is the heart of the microwave. Probably more expense than you would want to put in to it.I would recommend replacement unless it is a high end model. Hope this helps
Jul 24, 2009 | Whirlpool MH7155XM Microwave Oven
Not Heating!!
This seems to be a defective magnetron tube. Because of the very high voltage, (~5000 volts) you need to be experienced in this type of repair. Sending it out for service may cost around $150, so you need to evaluate the probable cost vs a new oven.
Jun 13, 2009 | Whirlpool MH7155XM Microwave Oven
DOOR HANDLE REPLACEMENT
Hi
Check this link
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Dec 06, 2008 | Whirlpool MH7155XM Microwave Oven
Whirlpool MH7155XM Microwave Oven Logo
23 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
