Question about Tablets & eReaders
Sony tablet The device freezed and won't started
  • 2,072 Answers
Option 1 (Non-destructive)
  • Press and hold the power until it powers off. This is considered a "hard reset"
  • Power the device back on.
Option 2 (Destructive)
  • Typically involves powering off the tablet. Once off tap the power button then press and hold Power + Vol Down until you get a menu
  • Us the volume buttons to navigate to "factory reset"
  • Use the power button to select it.
  • This will wipe out the tablet and reset it back to defaults.
Posted on Apr 24, 2013
  • amjad sawa Apr 26, 2013
    The problem is not resolved by following the two recommend options
    Regards
Mid model m729b
I have similar problem, my buttons on the right side including yjr start button have slipped inside the case and I can not restart the charged device, Can you help?
Pat Green, pgrex@hotmail.com, 409-782-2572, thanks if you can help.
May 07, 2013 | mid Archos M729B Android Tablet
Ainol Novo 10 Hero Tablet won't turn on/off on power button... it only works from reset button... also auto rotate doesnt work... Also whole tablet gets stuck always after 10min useage... ideas???
I have same problem as you have: the on /off switch completely not work . It cannot start only way use the reset pin then cannot off.Mine also has freezing problem.I went to setting then go to factory reset erase all my data. The freezing gone but the on / off switch still not work then I think this could hardware problem. Only way is open it up.Since this is a traumata act I have to use as the last act.Meanwhile I set the display screen close in 2 minutes when want to stop it.Any one here have any better idea please help.
Apr 09, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
I downloaded Skype on my 4Sight 9" Android 4.0 tablet but it won't open. How can I fix it?
I've had trouble with downloaded apps not working and everytime I did I would delete the app, turn my device off then back on, and then reinstall the app.
Dec 13, 2012 | Tablets & eReaders
I forgot my pass word to my proscan plt8031 tablet
This is everything you need to know to root/unlock/factory reset your Proscan 8" Tablet a.k.a. PLT8031.
First thing you will need to do is charge up your device, download the software needed to your desktop or some other easily accessable folder. Now this is the part that took nearly 3 days to figure out in order for the program to recognize and load an image to it you have to put the device in "recovery mode". You might ask well how do I do this, as every forum out there just says put in recovery mode and it will work, BUT HOW you still ask. The internet won\'t tell you, the company won\'t tell you, hell even other people on forums won\'t tell you. But alas I shall.
RECOVERY MODE Proscan PLT8031
Simply plug in your usb cable to your computer, then while holding your menu button, to clairify as I don\'t know the exact name of the button, it\'s the one to the left of the home button. plug in the usb cord to the device while still holding that button. Do not let go of the button until you see that windows has detected your hardware and is looking for a driver.
FYI windows usually will not find a driver, I have included links to the drivers you will need.Now if your at all used to device manager you should know how to point it to the driver you need. It will be called "rockusb.inf".
Once this is installed then open and run "RKBatchToolv1.4" as administrator. You then need to click the three dots in the top right to locate and load the "update.img" file. Make sure at this point that your device is recognized with a "green square" near the bottom of the window.
If all that checks out click the upgrade/restore button. To be clear it\'s one or the other, not both, technically didn\'t see a difference between them. This process will then start and will take between 5 to 10 minutes. DO NOT TOUCH ANYTHING. if you unplug your device too soon you will have a nice paper weight instead of a tablet. Wait untill it is completely booted into the setup your android device screen before closing the rkbatchtool and safely disconnecting the device.
Congrats on your newly rooted/recovered plt8031 tablet.
29RockUSB Driver - http://uploading.com/2ca29934/29Rockusb-zip
http://www.generalfiles.com/download/gs5a611f4bhci0/29Rockusb.zip.html
http://rapidlibrary.com/files/29rockusb-zip_ulcqxffyzwieon.html
If none of these work for you just google "29RockUSB" without quotes.
Firmware (update.img) - http://www.proscanvideo.com/tech-help/PLT8031.asp
RKBatchToolv1.4 - http://www.filecrop.com/RKBatchTool-1.4.rar.html
http://www.x-drivers.com/catalog/flash/tablets/companies/fuzhou_rockchips_electronics/models/rk_batch_tool/27575.html
Dec 06, 2012 | Tablets & eReaders
Why won't my PROSCAN Tablet let me download most
i reboot my device and it still won't work. it wont even let me download amazon or mobile 1 what can i do
Nov 08, 2012 | Tablets & eReaders
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
Tablets & eReaders Logo
93 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
