Question about HP Media Center m1080n (PC099A#ABA) PC Desktop
Computer will not turn on. Power supply shows flashing green.
Computer appears completely dead. Will not turn on. None of the fans come on. When power supply is disconnected from motherboard, power supply light glows steady green. I suspect a failed component on the motherboard, though I suppose part of the power supply may have failed. Anybody got any ideas? What does it cost to buy a new motherboard?
  • tbbccontract May 10, 2009
    computer does not respond when i try to turn it on. power supply has a flashing green light in the back of the unit. what could the problem be? i have an HP media center PC m1072n desktop.
Depending on the make of computer, a power supply cost's around $20.
Posted on Mar 15, 2009
    President:
  • 2,653 Answers
Hey Bob,
Sorry I got cut off earlier.
Let me know what model numbers you pull off that motherboard and I'll see if I can track down the right one for you on the cheap.
Thanks!
-RescueTechLA
Posted on Mar 13, 2009
Start up light flashes once and it won't power on
Most probable cause is the power supply. Look at the back of the computer, check the voltage settings located near the power cord. This will be the small red tab indicating two different settings, If your in the US it should be set to 115. Also, the power supply should run the internal fan when it is turned on.
To test the power supply try this:
Open your computer case and locate the gray box that is the power supply unit. Trace the wires from the power supply to the boards and devices and disconnect all the cables by unplugging them.
Find the big connector plugged on the the motherboard, make sure it is disconnected and short the two pins: (GREEN & BLACK) Short green pin (14) to GND (any black) to switch power supply ON, disconnect green from GND to switch OFF.
This will switch the power supply, you should hear or see the fan in the power supply spin. If you do not see the fan spinning, and your sure you have shorted the correct wires, you have a faulty power supply. If you see the fan spinning, you can now test the voltage coming out of the power supply.
Place a volt meter on the following colors to test voltage:
The color code for the wires is: Red = +5V, Black = Ground (0V), White = -5V, Yellow = +12V, Blue = -12V, Orange = +3.3V, Purple = +5V Standby (not used), Gray = power is on (output), and Green = Turn DC on (input).
Feb 12, 2011 | HP Pavilion a6110n PC Desktop
I turned off the computer by going to shut down earlier today I went to turn it back on this evening and the CPU won't turn on
hello, make sure nothing has come unplugged and that none of the buttons are stuck on. With that said if this is an older pc, your power supply inside the case might have went out. power supplies go out quite often, replacing them is not to bad just make sure you have the correct physical and power size. Also verify that it has the connectors for that particular motherboard.
hope this helps
Jan 14, 2011 | HP Pavilion a6650f Desktop PC
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
I think my HP Pav powersupply is dead. When I plug it in and try to turn it on, nothing happens to the HD and computer except a green light flashes on the back of the power supply. It is a Bestec...
all atx powersupplies are generic-it dous not really matter what computer it comes from unless its a high end pc requiring loads of power-if your machine is intel you may need a supply with an extra twelve volt lead(two yellow and two black leads in a little block)-but for that pc i would just harvest a powerpack out of a dead machine
Feb 25, 2010 | Compaq Computers & Internet
Try to turn on computer and the fan blows, but light jiggles and nothing happens. Hard drive shot or processor or ...???
Sounds like the power supply or the motherboard. If you have another computer available, you can test the power supply. Just "borrow" the power supply from the other computer. If it still won't come on, then the motherboard might be bad and you'll need replacement.
If you swap the power supply and the motherboard is bad, you will not hurt the working power supply. The motherboard is already dead and won't feed back to the working power supply.
Also, if you have flashed your BIOS recently and it has not completed successfully, you might have a dead motherboard and you will need to replace it. You would know if you flashed or updated your BIOS chip.
Hope this helps!
Oct 26, 2009 | E-Machines etower 600is PC Desktop
When i try to trun on my computer the fan doesnt stop so nothing goes to the screen
Oct 25, 2009 | E-Machines eMachines Desktop PC
2350 dead, not starting, just green flashing on board, no fans
Pull your hard drive and install it as a slave on another machine. If you can't read from it there, your hard drive is toast.
Oct 05, 2009 | Dell Dimension 2350 PC Desktop
When comp pluged in just a green flashing light
If you are sure that the 110 volt power is coming into the computer then the most likely problem is that th epower supply died. Obtain a new one of the same or larger wattagge as the one you are replacing . It does nto have to come from the manufacture of the computer.
Nov 26, 2008 | Compaq Presario SR1000T (568657) PC...
Won't Start
BLOWN YOUR FUSE NEED NEW FUSE IN THE POWER SUPPLY
Jun 30, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
HP Media Center m1080n (PC099A#ABA) PC Desktop Logo
448 people viewed this question
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
