Question about Toys
Nissan forklift error codes
Nissan forklift error code E-27 for L01/L02 models
2 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: clark forklift with error code
The description for code 15 is battery voltage to low. The code will flash when the battery volts are less than 1.95 volts per cell when the key is turned ON. Check the battery voltage with volt meter at battery were positive and negative connect. If the battery is 36 volt it should be no less than 35.1 volts, if the battery is 48 volt it should be no less than 46.8 volts. If battery voltage is low check each cell indavidually to locate a bad cell, each cell should have around 1.95 volts, if a couple are dramatically lower that may be your problem. If the battery checks out check your cables and connections (this seems likely because you say its after you charge battery, when you plug and unplug your battery in you wiggle the cables around witch could cause a poor connection.) Check over your cables carefully as corosion can grow inside of them especially near the battery and connector. Hopefully this helps, looking forward to positive feedback thanks.
Posted on Aug 25, 2011
What does fault 108-1 mean on a Yale forklift
Troubleshooting Yale - Forkliftaction.com
www.forkliftaction.com/forum/threadbybrand.asp?brid=97
No Trans Braking Error code 524264-14. Discussion started: 5 .... Error code 108-1displayed. Discussion ... Yale forklift has perkins 4203.2 engine oil capacity?
Oct 23, 2015 | Cars & Trucks
WHAT DOES FAULT CODE 676-4 REFER TO?
WHAT DOES FAULT CODE 676-4 REFER TO? - Fixya
www.fixya.com/cars/t25801863-fault_code_676_4_refer
Jul 30, 2015 - ... 676-4 REFER TO? HYSTER FORKLIFT 3.0 FORTENS ENGINE 3STAGE WITH SIDE SHIFT FAULT CODE 676-4 - Cars & Trucks question.
FORKLIFTACTION.COM (Forklifts) - Site Map - List all forum ...
www.forkliftaction.com/sitemap/forums.asp
Find forklift manufacturers, dealers, suppliers and other lift truck ... What do we know about the PSI 2.0L and 2.4L engines? .... nissan platinum error codes. ..... what have change do I all to go at hyster forten truck of montrol pendaal to ..... Raymond EASI - NO reach, tilt, or sideshift. ...... Hyster 5.5FT fault code 676-4 [view]
Jul 30, 2015 | Cars & Trucks
Mitsubishi rocla forklift error code list
WHAT MEANS OF 15 ERROR CODES ?
If you can help for the error codes means we will be very happy .
Thanks for help.
Please answer : onur@egemenforklift.com.tr
Mar 09, 2013 | Computers & Internet
Tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
Jun 21, 2010 | Clark Forklift Horn Button Switch , Cat...
I have a kodak dx 6490. when i turn on the camera display shows error-L02 what is this.
Hello, You have just joined the ranks of many other owners,This code means your camera has a fault code and needs to be checked by a qualified repair person to determine the cause of the fault.
Best Regards,Russell
Jan 13, 2009 | Kodak EasyShare DX6490 Digital Camera
Videoseven (V7) LTV32DA LCD TV black screen, blinking led
That is correct in assuming that this is a code and it is related to that on-board processor protocol. Yes, many screens are used on many different chassis, but the ways to the means is not always the same. So, you have a schematic for this motherboard? What problem are you having with this set?....accordianman
Feb 27, 2008 | Televison & Video
Toys Logo
863 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
