Question about Raymarine C80 GPS Receiver
Nmea 5-pin I need to connect the GPS to my VHF for DSC. What plug do I need? Radio indicates it wants a NMEA out (-), a NMEA out (+) and NMEA in (+).
2 Suggested Answers
  • 8 Answers
SOURCE: what is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Posted on Jan 25, 2012
Connected marine radio to humminbird gps antenna but the radio will not show gps
Hi Ken
A little wiring 101 is in order here I think.
NMEA out (+ and -) from your GPS goes to NMEA in (+ and -) of your VHF.
Hope this helps you out
Mar 10, 2016 | Humminbird Boating
How do I connect my Garmin GPSMAP 451 to a Standard Horizon GX1200E VHF radio, eclipse DSC?
Hi
You'll need to identify and connect NMEA out (+ and -) from your 451 to NMEA in (+ and -) to your VHF to get it done.
Hope this is helpful.
-Steve
May 04, 2015 | Garmin Boating
How to hook a uniden vhf radio to a garmin 4208 for nmea operation?
Hi
I realize this question is old, but for the benefit of someone else who might have the same query, the NMEA 0183 outputs from the 4208 are the gray (+) and black (-) which go to the data in of your DSC VHF. The data OUT from your VHF connect to the white (+) and black (-) of the 4208.
If using NMEA 2000, using the second link below, start on page 10.
The installation instructions are about halfway down on the link page and can be accessed directly from the install link below if you prefer. -Steve
http://support.garmin.com/support/manuals/manuals.htm?partNo=010-00591-01&language=en&country=US
http://static.garmincdn.com/pumac/GPSMAP_4000-5000_Install_EN.pdf
Apr 28, 2014 | Uniden Boating
Colour codes of output data cable explorer 650
From the owners manual (page 78, link below) NMEA out (+) is the white wire and NMEA (-) or ground is the black wire.
-Steve
http://www.northstarnav.ca/upload/Northstar/Documents/EXPLORER_650.pdf
May 14, 2012 | Northstar POWER/DATA CABLE FOR EXPLORER...
What colours do i use to link my 128 with my dsc radio
Hi!
From your Owners manual (Page 59) The BLUE wire (Pin 3 NMEA out) from your GPS goes to the NMEA in wire of your DSC radio. The ground pin from your GPS is pin 2 (Black)
Just in case you've misplaced your manual, here's the link you need.
http://static.garmincdn.com/pumac/82_OwnersManual.pdf
Hope this helps and Happy Boating!
Jun 16, 2011 | Garmin GPS 128 Receiver
I have a Philips GPS Dantronik Navigater MK9 an now a Northstar VHF Marine Radio Explorer 710. I want to connect both over NMEA to get the position form the GPS to the radio. There are 7 different...
I connected my ICom using the NMEA in. I had the leads reversed first time, moved them around and worked. This was a connection from Furono to iCom but should be much the same
Jun 01, 2010 | GPS
I have bought a ICOM VHF m601 and I want to connect the furuno gps 31 to the VHF. Is this possible ?
Using the nmea output from your GP-31 to the nmea input on the VHF. Enable the GLL Sentence and make sure the port is set for nmea0183. Remember hooking nmea up it's positive to positive and neg to neg. Once that is done and you have a fix you should have lat and long on your vhf.
Mar 09, 2010 | Furuno GP31 GPS Receiver
Does this unit have a distress signal that a Nema 0183 data cable can attach to
See below:
GPS RECEIVER LEAD
Connects to a GPS receiver for position indication.
• An NMEA0183 ver. 2.0 or 3.01 (sentence formatters RMC, GGA,
GNS, GLL) compatible GPS receiver is required. Ask your dealer
about suitable GPS receivers.
Color code:
Yellow: NMEA IN (+)
Green: NMEA IN ( )
Feb 19, 2010 | Icom M302 VHF Radio
My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Jun 09, 2009 | Raymarine Raychart 435 GPS Receiver
Raymarine C80 GPS Receiver Logo
49 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
