How can i fix my computer it does not continue
When i switch it on it only shows a menu for the drives and setups.when i set it up it shows a white dash on top left,it wont show the main screen
    Brigadier General:
  • 3,400 Answers
You write drives i suppose you mean HDDs 1 or 2 maybe 3.
if set optimal defaults in BIOS.BIOS can change drive to boot from
windows is at one of them.
Posted on Apr 23, 2013
Johnboy36
  • 77 Answers
SOURCE: Computer no responding
The system is looking for a device to boot from. Make sure that your hard drive is properly connected, then make sure that it is the only drive connected. Remove any USB thumb drives, CDs and floppy disks. Now leave the case off while you switch on so that you can ear the HD spinning. if you can't, the disk may be damaged and need replacing.
Posted on Feb 25, 2008
SOURCE: acer computer t180 boot up problem
DOES NOT OPEN ONLY NOISE
Posted on Apr 12, 2009
  • 225 Answers
SOURCE: my computer shows to setup array and does not detect one hard disk
Please try to system reformat/reinstall OS to your HDD under SATA connection. then kindly check the jumper setting of HDD under IDE connection which I suggest to place it at Master while the SATA HDD will be automatically recognized as Slave by your computer. best regards
Posted on May 16, 2009
leecom72
  • 4806 Answers
SOURCE: My Dell desktop computer is plugged into a master
The CMOS/BIOS battery has died and needs replacing.
The battery is located on the motherboard inside the case of the computer.
To replace the battery you'll have to open the case up and replace the battery. It looks like this >>>
Once you have replaced this battery and restarted your computer you will need to access the BIOS to set the date, time and also tell the computers BIOS that the floppy drive is not there and to set the boot order of the computer.
Once you have done all this you should not get that message again for a good few years.
Regards.
Posted on Jul 16, 2010
  • 4088 Answers
From your description, you have acquired a fine virus that is reorganizing your system--suggest getting some professional help for a virus scan and clean plus getting rid of the extra programs. Also, check the condition of your CMOS battery. This service is not cheap, but may be essential in this case. Good luck!
Compaq Presario pops up a system boot menu everytime at startup.
This comes up mostly when it requires a BIOS save. Try that. If that does not help, sometimes setting the default settings and saving will help.
Dec 04, 2012 | Computers & Internet
OptiPlex GX400 can't find the CD drive and can't find the hard drive
hey, if the machine boots into windows but doesnt show the cdrom drive in my computer, might be you have had norton on in the past theres a common fault that makes the drive disappear, the fix is on this page http://www.facebook.com/l.php?u=https%3A%2F%2Fwww-secure.symantec.com%2Fnorton-support%2Fjsp%2Fhelp-solutions.jsp%3Fdocid%3D20090430144107EN%26lg%3Denglish%26ct%3Dunited%2Bstates%26product%3Dhome%26version%3D1%26pvid%3Df-home%26entsrc%3Dredirect_pubweb&h=jAQEyPa4V
if the drive aint showing in the bios, make sure you have the jumper on the drive set correctly to either slave or master depending on how its cabled. hope this helps ;)
Jun 12, 2012 | Dell OptiPlex GX400 PC Desktop
Computer running slow
I'd say the bigger problem is it is having problems reading the HDs. That will affect everything it does since it will constantly try to fix that. Obviously, disconnect and reconnect every connection between the HD and the motherboard. Also consider replacing the cables. If still dead your hard drives may have gone bad.
Dec 04, 2011 | Dell Computers & Internet
Diskette Failure F1 to continue or F2 to run setup??
Your computer is looking for a Floppy diskette drive. If you entered the BIOS ( setup menu ) and selected default settings to be applied it selects the first boot-table drive as the floppy diskette drive. You have to disable the floppy drive if you don't have one.
Sep 06, 2011 | Dell Dimension 3100 PC Desktop
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
My PC doesn't load
Restart computer. Watch closely at the bottom of the screen for an F command.
This F command will allow to enter setup.
When computer is loading, start pressing F12 repeatedly until setup is opened.
When setup opens, you'll see a file menu that runs across the top of the screen. It will start from the left and move to the right - press F9. When prompted, select "restore default settings". Move to each file menu and press F9 and set "default settings".
When you come to the Exit menu, do the same thing, then select the Exit Menu, and choose the "Exit Saving Settings" option.
Once it exits, it will automatically restart and begin the loading process into Windows (or your operating system).
If the OS does not load, you will need to re-enter setup: under the file menu, search for an option that will allow you to enable a second F command which should be F5 or F10. Once this is done, go to exit, and select "exit saving settins".
The computer will begin loading, but you will want to restart the computer - watch again at the bottom of the screen for the new F command - remember what it is when you are in setup, and begin pressing it as before with the F12 command - the F5 (F10) will bring you to an option menu for starting the computer - select the "start in safe mode" option.
If the computer does not load in safe mode, you will need to format the hard drive and re-install the Operating System.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jul 23, 2010 | Acer Aspire m5640 PC Desktop
My Dell desktop computer is plugged into a master switch. But I still have to turn on the computer to use it. Lately when I turn on the master switch, the computer turns on automatically. But the Windows...
Press F2 to enter the system setup. Someone or something (Bad Motherboard battery most likely) has reset the BIOS defaults, which includes the Floppy diskette drive controller to be ON. Set Diskette Drive to NONE, then under integrated Devices, set diskette controller to off, save settings and reboot
(ALT + B)
if issue re-occurs then the watch battery on motherboard is bad and needs to be replaced
Jul 16, 2010 | Dell Dimension 3000® Pentium® 4...
Regards.
Jul 16, 2010 | Dell Computers & Internet
Bios setup cannot detected 500gb sata Maxtor
hy on your maxtor hdd you have a jumper configuration you have to put your jumper in the good configuration so your primaries hdd is the one that have the exploitation system and the other one you need to set it to secondary hdd
bye and good lock
Mar 06, 2009 | Maxtor Hard Drive
Press F1 to continue and f2 to setup. How can i remove it please?
after pressing f2.....bios setup was opened.....go to drivers.....and than open diskette driver.....select off .....your problam is solve 1000%
Dec 05, 2008 | 10 10 Computer Network adapter Cable...
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
