Question about Health & Beauty
Help fixing my avanti ultra
I have an avanti ultra nanotech ceramique and the chord is loose. if i jiggle it, it will turn on, but as soon as its moved again it shuts off. anywhere i can send it to be fixed/replace the chord/anything i can do so i dont have to flat out buy a new one?
joshy999
  • 241 Answers
SOURCE: Broken inside LCD screen on LGShine
hey guys you can now use http://horizonwirelessonline.com for all repair services.
theyre just setting up, but they have 100's of parts for all the new phones - they can do the repair or send you the parts for you to do at home!
Posted on Dec 07, 2007
  • 9 Answers
SOURCE: viewsat Ultra
www.ftabins.net
Posted on Jan 06, 2008
cammedic
  • 667 Answers
SOURCE: Tamron 28-300 loose lens parts
The way in to this lens is from the rear. You'll need to remove the trim ring inside the mount and free the electronic connector from the mount ring before you remove the mount ring itself.
Posted on Jan 19, 2008
SOURCE: hp flat screen monitor
Wow tons of people have this problem (myself included). What a horrible monitor.
Posted on Mar 15, 2008
  • 6 Answers
SOURCE: Flat Screen trouble
you need to replace switching transistor 2SC5707 in the Power Inverter Board.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
Posted on Nov 04, 2008
No sound. Lights up
Try this instead, when you look at the back of the receiver, try and jiggle each chord connected, just to see if one might be loose.
IF NOT -- try and make sure the settings on your tv is correct, most receiver boxes use and HDMI cable for video and ausio as a dual connection so if the HDMI settings in your internal settings are off, you might need to update the settings and then it should work
Jun 16, 2015 | Audio Players & Recorders
Emerson MW7300W7 acting strange.
You may have multiple problems with this unit. All of them might have been caused by a loose connection on the power cord. If current is abruptly interrupted when it is running, any component which contains a coil of wire (transformers, relays, etc.) will generate a voltage spike. These spikes can take out sensitive electronic components. I suspect that is what happened to this oven.
Apr 29, 2014 | Emerson Microwave Ovens
Fan runs but it doesn,t cool
Your Peltier is most likely shot! You can fix it for less than $10 in about 30 minutes.
Take the back of the fridge apart and remove the fan and aluminum heat-sync. Sandwiched in between the heatsync you'll see the Peltier pad with two wires coming off it. That's what you need to replace. The peltier has a make and model number on it. I would recommend ordering the same make and model. The specs should be 12v DC and less than 5amp and 60 watt draw. Your wine cooler's power supply can only output 5amp and 60watt max power. When you install the new Peltier you'll need to spread new thermal compound on both sides of the Peltier. I recommend Artic Silver Ceramique. You can buy this at your local Radio Shack or any computer store where they sell motherboards and CPUs.
Ceramique Thermal Compound
New TEC1 12706 Thermoelectric Cooler Peltier 12V Ceramique Thermal Compound
Feb 28, 2014 | Cuisinart CWC1600 Wine Cooler
Red line on sceen?
I had a similar problem with my LCD screen TV, and to my dismay, my warranty just ran out. A thin red line began to appear on the right side of the screen, and since many online and expert sources pretty much say replace the expensive LCD screen or get a professional to fix it (in which I suspect to be a business plot to get people to go to pricey experts), I decided to look for other possible alternatives.
Here is some tips/solutions I was given (and it worked! at least for me):
1) Turn off the LCD and unplug the power source and let it rest for 5-10 minutes. Turn it back on and see if it disappears or improve. (This is the one I used.)
2) While turned off, try jiggling gently all chords connected to the TV (cables, power chords, etc.); you could even try unplugging and replugging the chords/cables. Turn the TV back on and see if the red line disappeared or improve. (This is the one I heard worked for others.)
If the above doesn't work then I'm afraid you do have a bad panel on your screen and will need to call in the experts or get a new TV. I hope this will help. Best Wishes.
Nov 12, 2012 | Dell E207WFP LCD Monitor
My avanti ultra hair straightner does not heat hotter than 230 deg..id there a reset button..help?
I have the same problem!! It switched from farenheit to celsius thats why its at 230 but i want it back in farenheit!
Sep 18, 2011 | Avanti Ultra Silicone and Ceramic Flat...
Computer stopped receiving power and won't turn on.
When you move the hard drive from one computer, it won't boot up unless the both computers are exactly the same model and configuration and with the same installed devices.
Generally you need to install Windows again to get a functioning computer when you transfer a hard disk into another computer.
Jul 29, 2009 | Gateway MX8711 Notebook
Problem power chord
The problem that you Actually Have, Is that the Mains In DC Jack on the Motherboard. Has worked Loose.
You need this replacing A.S.A.P as it,s burning your power packs out, it,s also possibly arcing across the motherboard.
If you look on the internets largest Auction Site :) services are offered to repair these. Usually varying From £40-$80. Plus, Dependant on sending the complete laptop, or just Motherboard.
Alternatively A Computer repair centre. I,d estimated £100-$200 Maximum. But worth Doing to save your Motherboard And future power pack purchases.
Mike @ Compurepair.
Jun 26, 2008 | Acer Aspire 1642WLMi Notebook
WILL NOT RUN (KSM90WW)
theadore something is not connected right or something else got disconnected. there is no reset on these mixers. may i ask why you removed the back housing?
May 01, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
No Power
i'm having the same problem.
check the power supply chord that connects into the tv. I have to adjust a jiggle the chord until the red light on front panel comes on.
The power supply chord needs to be replaced.
Aug 16, 2007 | Toshiba 20HL85 20 in. LCD Television
Health & Beauty Logo
96 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
