Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
Toro Z4200 Starts, Runs, but wil not move and Arms are resistant
I was mowing outside and the mower's arms just stopped moving (or giving me resistance) so i disengaged the blade and what not. Well it is sitting there and will not go forward or backwards. Even when I pull the pins on each side that lets me push the mower, the mower will not move manually either. It will neither go forward nor go into reverse. Again, the engine still starts, the blade engages and disengages great, I replaced some fuses. I was thinking a belt problem or something so I checked them and need to double check since its daytime, but it happened while mowing. I need help fixing this and if anyone could give an explanation along with a picture or digram so I can see where and what I need to do. ANY HELP IS MUCH APPRECIATED WITH SOME KIND OF DIAGRAM WOULD BE GREAT OR LINK TO ONE. THANKS!!!!!
5 Suggested Answers
  • 2926 Answers
SOURCE: Hello my name is David I have a 50inch toro ride
Why wasn't the mower just started up and moved under it's own power, instead of disconnecting the handles? Did the mower run prior to handle disengagement?
Posted on Apr 26, 2011
dcramer531
  • 1654 Answers
SOURCE: I have a Toro 38"
Have you checked out the seat safety switch and also is your mower capable of cutting in reverse? There are aslo safety switches on some models that kill the blades when backing up. Check these and see if you can find an issue with one of these. Sounds like one of the safety switches is going bad and killing the blades and then restarting them, if not then you may have a bad electric clutch or a loose wire on the clutch. Let me know what you find.
Posted on Aug 15, 2011
  • 747 Answers
SOURCE: Toro Z4200 Kohler engine. I was mowing and shut the mower down. When I tried to restart it would not start, not even a single fire. Starter works fine.
check for spark is the wire on the spark plug is the plug good check for fuel flow possible electrical short
Posted on Jul 07, 2012
  • 6468 Answers
SOURCE: my toro eztimecutter just stopped moving forward or back, engine runs and mower runs but doesn't move
check the drive belt that goes from the motor to the pumps
Posted on Sep 29, 2012
Mx5050 toro zero turn mower, one drive arm more dominant than the other. With both arms all the way forward the mower slightly turns to the left. Any adjustments to correct this issue?
1st with mover off verify that both handles move same amount forward , I use a string to measure them , they both have mechanical stops that do bend and move sometimes
second locate control body valve , (thing that handles connect too) there should be a pump pressure adjust (allen key) on the side of this your gonna need to make small adjustments and try it , is difficult to do if you don't have a lift to elevate wheels of mower (but is possible without ) but takes patience
Apr 25, 2015 | Toro Garden
I have a toro zero turn z4200 starts and runs fine but when I put arms in gear, it will not move forward or backward.
Make sure the drives are engaged. Under the seat and towards the rear are two thin metal levers with finger loops. These are used to disengage the drives in order to push the mower when the engine is off. Levers towards the back to engage.
Good luck
Mar 30, 2015 | Toro Garden
Right side tire will not engage
bad check valve or bad hydro pump you got to take in
Sep 05, 2014 | Garden
Toro Z4200 hdro won't stay in neutral
Your throttle csble is stretched it needs a new one
Dec 15, 2013 | Toro Garden
Looking for some help. I've got a Toro Z4200,
there is only one way gas can get into the oil. if someone is pouring it into the crankcase...good luck
Apr 05, 2010 | Garden
The motion control levers became tight to move and
You may have some bent or out of adjustment linkages, causing the brakes to stay on.
Or the friction nut (one on each transmission) is too tight. These are located just in front of the axel, they go through a slot, the washer behind the nut should turn freely
Aug 15, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
118 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
