Whdvh626fww bearing replacement
Can these bearings be replaced? GE says I need to replace the entire rear tub
    President:
  • Washing Mach... Master
  • 662 Answers
bestdarngood
  • 3037 Answers
SOURCE: Spin Cycle is very loud on front load washing machine
yes, you can, if you need a place to buy a new bearing, let me know the make and model and I will get you a link to purchase one from
Posted on Sep 04, 2008
stradeteox
  • 88 Answers
SOURCE: replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
Posted on Jan 08, 2009
  • 103 Answers
SOURCE: NEED TO REPLACE REAR BEARING.GOT A NEW
really tedious job. if you are really keen, pl. follow.
remove motor, remove shoker top pins, remove top stone, remove all hose connecting drum, remove heater/other connections, remove door gasket from front, support drum from top, remove springs, lower drum, dismantle drum in two pieces, remove inner steel drum.
well rest i think you can think yourself.
Posted on Oct 30, 2009
  • 17 Answers
SOURCE: whirlpool ghw9100lw2 bearing repair
Bearing cost about $450.00 plus labor. Major job. Better looking for a new washer. Sears outlet sell good washer at cheaper price.
Good luck
Posted on Aug 11, 2010
caroldon
  • 17130 Answers
SOURCE: The bearings in the Maytag
If you think that there is no shake or play in the bearings a good wash with kerosene or diesel will take away all the dirt that causes the noise. The use light grease/heavy oil (90) to fill into the bearings.
Tip: repeat the washing with the diesel, use a good small brush and hold a tray under to pour the diesel and collect on to the tray till the noise subsides.
However if the bearings are still noisy then I think you need not replace the drum .
If Helpful credit me for the tip.
Posted on Aug 20, 2010
Where would i get a drum bearing for my GE WHDVH626FWW, or the part number would be?
Try www.vvapplianceparts.com and type in your model number. You will get a complete picture breakdown of the parts with prices.
Mar 15, 2016 | GE Washing Machines
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Maytag Washing Machine roars when it spins
Hi, if the tub is roaring when it's in spin mode, that means that your main rear tub bearing is going out and will need to be replaced. Unfortunately you can't just replace the bearing because it's built into the rear outer tub so the entire rear outer tub needs to be replaced. It's actually quite a major repair and costs about $500-600 to have it replaced. If this happens to be less than a year old then definitely call warranty to have this repair done so that you don't have to pay for it.
Aug 01, 2012 | Maytag Washing Machines
Loud noise during spin cycle kenmore model # w110.4770 front loader
When the rear bearing goes the best thing to do is shop for a replacement.
The rear bearing is not an economical repair to make and will cost more then the replacement with a similar new washer.
The bearing is built into the rear half of the tub and the entire washer must be torn down to replace it.
Apr 25, 2012 | Maytag Washing Machines
Replace bearing
Dec 02, 2008 | LG WM-1832C Front Load Washer
Bearing failure
you have to pull entire tub assy out of mach,removing all hoses,motor,wiring shocks and springs.then you remove all the bolts going around the middle of front and rear tub.the bearings and seals are pressed into the rear tub and are not removable for separate replacement.rear tub and basket have to be replaced together and is quite expensive to buy these parts..good luck
Sep 24, 2008 | Kenmore 44102 Front Load Washer
Rear bearing noise when drum rotates
If the rear bearing is bad it will require the replacement of the entire rear tub shell. This is because the bearing is molded into the plastic and cannot be replaced separately (I know, its a stupid design). Sometimes additional damage can occur and the inner spin basket and front shell may also need replaced. In addition, what may seem like a bad rear bearing, might be a broken tub support on the spin basket. In a nutshell, you may have to replace both tub shells and spin basket at a minimum. With parts and labor the repairs could cost $600-$800. If you have no extended warranty or service plan coverage, it may not be worth the effort to repair due to the excessive cost. Sorry...I wish I had better news for you. I hopes this provides you with some answers.
Oct 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
537 people viewed this question
Top Washing Machines Experts
