Question about Electrolux Washing Machines
E1 - Electrolux Washing Machines
  • Official Brand Answer
  • 4,342 Answers
Good Morning shannon galway - Could the unit possibly be experiencing an E10 or E11 and not displaying all of the numbers correct? If so, both error codes indicates that the water is taking too long to fill.
Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from the unit. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
However, if you are not experiencing either of these two error codes, is your unit an international model? If so, this could mean something completely different, which I would personally suggest reaching out to the manufacturer directly for further assistance.
Posted on May 24, 2013
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What does code e1 mean
    E1
    2.048Mbits/Second
    Computing » Networking
    Rate it:
    E1
    Echelon 1
    Governmental » Military
    Rate it:
    E1
    Electrician Ist Class Petty Officer
    Governmental » Navy
    Depends on where you're reading the code from as well!
    May 11, 2016 | Heating & Cooling
    My air conditioner showing on the display is E1
    The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
    For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
    How to Fix an Air Conditioner When It Gives You an E1 Code eHow
    Jan 24, 2016 | Heating & Cooling
    What does E1 code indicate?
    Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
    How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
    sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
    Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
    Oct 27, 2015 | Heating & Cooling
    E1 error code on omega dishwasher
    E1 error on LG Dishwasher - YouTube
    ? 2:40
    www.youtube.com/watch?v=2qcwAyHI9ik
    Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
    Aug 28, 2015 | Dishwashers
    Busco manual de ACER Aspire E1-572/E1-570/E1-532
    Hi
    The link below will take you to the page for the Aspire E1-572 where you can choose from drivers, documents, BIOS upgrades etc and download exactly what you want.
    http://www.acer.co.uk/ac/en/GB/content/drivers/4776;-;Aspire%20E1-572
    Cheers
    Sep 29, 2014 | Computers & Internet
    What does E1 mean in tadiran 250 R, it works then stops and screen shows E1 when it operates as a heater
    h Air Conditioners
    Nov 24, 2012 | Heating & Cooling
    E1 fault on kenwood dishwasher kdw243a
    error code E1 refers to "lack of water inlet pressure" the valve the elctrically lets in the water might be at fault
    Jan 18, 2009 | Kenwood KW85 Air Conditioner
    Washing Machines Logo
    120 people viewed this question
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
