Dvi rca wiring diagram - Televison & Video
I have a Rca scenium tv ...trying to connect to my hd reciver and can not get a picture ...tried hdmi cord ..adapter ..dvi cord ..and nothing at all
Easy to understand, hooking up RCA, HDMI, and othe ...
? 5:54
https://www.youtube.com/watch?v=m4jgK7Ws_6U
Jul 10, 2012 - Uploaded by kevintalkstech
A very easy to understand tutorial about what RCA, HDMI, coaxial and ... +kevintalkstech I am trying to learn ...
How To Connect: Tv + Component With Dvi Or Hdmi - Rca ...
www.manualslib.com > ... > User manual
RCA SCENIUM HDTV With DLP Technology High-Definition Television ... To connectyour TV to a component with a DVI jack, use an HDMI cable and an ... Note: You canset up the TV to automatically tune to the correct Video Input Channel. .... call me at 318-578-5198 I need help as soon as possible trying to get my tv to ...
Support - RCA Television
Dec 27, 2015 | RCA Televison & Video
What's your problem?I just purchased a I just purchased a Sharp LC32SV40U. I'm trying to hook it up with my Shaw Direct DSR 505 receiver (DVI to HDMI. I cannot find how to get sound using this
When using this type of adapter you only feed video into the TV/monitor
you have to use a separate set of RCA audio wires to feed the audio into your tv.
Nov 24, 2012 | Sharp Televison & Video
Connecting playstation 3 to my sanyo Vizion to my HDtv
Well theres a few diffrent ways to connect a ps3..u can connect it with a rca connection,,thats the standard one that u should have,,,do that first,,,then connect your other one while ps3 is on the screen with the rca one ,,go to settings under display,,choose hd setting for your tv,,,then onece you plug in connecter u choose to use ,,it will detect it,,,unplug standard one,,there u go,,that tv,,should have dvi ,rca,and component,,,thats the red ,green ,blue,,thats a hd connection,,so is dvi or hdmi,,,if tv has dvi,,get a dvi adapter to hdmi,,at walmart,,hook it up,,good luck,,
Dec 23, 2011 | Televison & Video
What do I need and what wires should be run to be able to run a VCR/DVD player and a laptop to a single projector?
VGA/ DVI cable - can be used but it depends on the projector inputs. you can run DVD player and laptop to your projector but simultaneously only.
Kindly give feedback if I helped you. Thank you for posting.
Jul 02, 2011 | Computers & Internet
Can i connect by apple computer to my tv i have a ws65903 mitsubishi projection with s-video and rca connections.
No worries, you can get the mini-DVI (for macbooks) to rca adapter. You can purchase this on store.apple.com for $19. Just plug the yellow RCA wire into this and VOILA! Mac to TV! You might also try Ebay.com. They usually have them for less and shipping is usually fast (if you buy in the US and make sure they have decent feedback...my rule is no less than 90%) I hope this helps you! Don't forget to vote. On Fixya, we rely on your feedback. I posted a picture of the mini-DVI to RCA adapter below:mini-dvi-to-dvi-300x210.jpg
Apr 25, 2010 | Mitsubishi WS-65903 65" Rear Projection...
I wANT TO CONNET MY LAPTOP TO MY CRT TV
What you need:
This is hard to define initially as there are so many ways to achieve this depending on what type of television you have and what video outputs your computer offers. You may also find that you only want to attach the stereo, and leave the TV disconnected, or vice versa.
.HDMI - High Definition Multimedia Interface: Ideally we will all have an HDMI connection on both our television and video card, but most likely don’t have it on either. Many new LCD screen and Plasma displays offer this mother of connections. They are also becoming a little more popular on Video cards. This will give you the highest quality signal. This format can also carry audio. This is very easy to connect from one device to another. It offers the same video quality as a DVI.
here are some tips that will help
Computer has HDMI and TV has HDMI – Use HDMI
Computer has DVI and TV has DVI – Use DVI
Computer has DVI and TV has VGA – Use VGA + Adaptor
Computer has VGA and TV has VGA – Use VGA
Computer has S-Video and TV has S-Video – Use S-Video
Computer has RCA and TV has RCA – Use RCA
Computer has S-Video and TV has RCA – Use RCA with adaptor
Computer has RCA and TV has S-Video – Use RCA with adaptor
Sep 10, 2009 | Gateway CX200S Tablet PC
Comp to dvi problem
there are some settiings on your laptop you need to set specific for tv monitors different dvi format is used
Nov 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No sound ondvi or cmp
A DVI cable does not transmit sound, DVI is video signal only.
There should be one primary RCA Audio out and you may want to poke around in the settings and make sure it's enabled.
Aug 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
DVI to RCA3 AV OUT
DVI to Composite Video (yellow) adapters are available in many online stores for mail order. You will need to get a separate mini-RCA jack to stereo RCA adapter to hook the audio output from the computer to the stereo audio (red and white) connections of the cable.
Search google for DVI to composite video adapter, and the mini-RCA adapter can be found at most home entertainment or electronics stores (Best Buy, Circuit City, etc)
Jun 10, 2008 | Dell XPS 200 PC Desktop
HDMI
Use the input button on your remote control... as you press input you should see VID 1, VID2, COMP 1, FRNT and then DVI... When you get to DVI you should see your picture..
Oct 15, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
