Question about HP Pavilion dv1000 Notebook
Hp pavilion dv1000 laptop pc keyboard not working properly.
Keys v and n when stroked i get a letter and a number v6 n5 also space bar iget ///// when pressed if i hold down the v n numbers dont show ...i swaped keyboard for a new one did not fix it also tried external keyboard the letters did not show at all. please help thank you.
  • itchi777 Mar 13, 2009
    I have the same problem as i posted:
    "I seem to have a problem with the motherboard of my DV1000. The
    keyboard goes haywire. Before it just types wrong letters and gives off
    continuous beeping sounds. But now it became worse I can not type
    anymore and the continuous beeping sound is still there. When I try to
    press caps lock the wifi goes on and off and other weird stuff. I tried
    trouble shooting it, reformat and all. And it seems that the problem
    occurs right after I install the audio drivers. I am now using the said
    laptop with only internet wifi drivers installed and still very often
    the problem occurs but disappears when i restart the computer."
    I was told that it might be the motherboard since using external keyboard didn't help.
  • 748 Answers
Does this computer KB work alright in SAFE mode? If it does then drivers and/or viruses are the problem. If it doesn't work in SAFE mode then it could be drivers and or keyboard. Now try booting into BIOS. At the date prompt you usually can type any keyboard letter. If the keyboard works here, then you definately have driver/virus issues. If not replace the keyboard.
Posted on Mar 26, 2009
2 Suggested Answers
kbdesign
  • 370 Answers
SOURCE: keyboard problem hp pavilion dv1000
Think you have the Num Lock on. Tap it once, and all should be good.
Posted on Mar 19, 2009
Hp pavilion, some keys not working including space bar. the bottom keys and some number keys, please advise
If the computer is under warranty, I recommend contacting HP for support, otherwise you will likely need to have the keyboard replaced, or if the computer is over 3 years old, I would recommend purchasing a replacement.
Nov 14, 2016 | HP Computers & Internet
My HP Pavillion keyboard is keying properly
az i think your keyboard language has changed. from language bar you should change the language of keyboard. control panel-region and language- keyboard and language- change keyboard.
Apr 06, 2010 | HP Pavilion dv7-1020us Notebook
I have a laptop hp dv 1000 when i turn on tonight the key boar and mouse was not working at all. an error message"there was a problem installing this hardware Standard 101/102-key or Microsoft Natural PS/X...
try and download the driver for mouse and keyboard from maunfacturer site and installed it on your laptop i guess the driver are not properly installed on your laptop
Dec 08, 2009 | HP Pavilion dv1000 Notebook
The keyboard has a keypad, but when y turn on the num lock, the letter keys will also start working as a keypad. My computer is an HP Pavilion dv9730us Notebool PC. It has a full keyboard, with a keypad...
Sorry but you found what is NORMAL for laptops. this is not a bug, error, fault, etc.
It does exactly what it is supposed to do even though it may have a proper number pad too. leave num lock off
Aug 09, 2009 | HP Pavilion dv9730us Notebook
Keyboard problem hp pavilion dv1000
Mar 19, 2009 | HP Pavilion dv1000 Notebook
Thanks for your support
Remove the keyboard screws first, the screws that secure the keyboard have keyboard symbols next to the screws.
Some Compaq/HP have slide catches along the top edge of the keyboard between the number keys and the Function keys. Usually the slide catches are located between the ESC & F1 key, F4 & F5 key, F8 & F9 keys, F12 & delete keys. Slide these catches towards the front edge of the keyboard (ie. towards the space bar) you should be able to lift the keyboard clear. Don't forget to unclip the ribbon cables on the keyboard.
Jan 28, 2009 | HP Pavilion dv1000 Notebook
Numbers are displaying when I hit a letter on the top line
You are stuck in num lock press num lk to get out
Dec 12, 2008 | HP Pavilion dv1000 Notebook
HP PAvilion DV 1000 Keyboard Problem
Seems like it actually may be a problem with the keyboard. Could be that those particular buttons are faulty. I would try a new keyboard. They seem to be cheap enough these days!!Hope this helps!
Oct 01, 2008 | HP Pavilion dv1000 Notebook
Hp dv8000 keybpoard problem
Hello! am Fabian,
problem.
every time i press a letter another letter shows up the space bar ...
solution.
first, be show to check if any other key is down, if not, dust your keyboard/pad to make sure the keys are free. if you problem remains, its likely your keyboard may be moist. you have to dry it by opening/ exposing it internal circuitry's to a dry air for some hours then close it up and test. if this did not work, it means you will need to replace your keyboard/pad.
when drying do not expose to direct sun light. if you have to replace the keyboard/pad buy an exart from your system manufacturer if you can.
i hope this information will be helpful.
Thanks.
Sep 21, 2008 | HP Pavilion dv8000t Notebook
HP Pavilion dv1000 Notebook Logo
1,197 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
