Question about Eureka 5893AVZ Bagless Upright Cyclonic Vacuum
Vacuum shut off while in use. almost new. now it won't turn on. other outlets work so not a breaker.
    Problem Solver:
  • 13 Answers
Not sure if this will help, but this is how my problems began, then I noticed the handle getting very warm. This went on for a few weeks (used the vacuum maybe 4 times).
Eventually, the handle got hotter and hotter, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Posted on Jan 30, 2010
2 Suggested Answers
Vac Belts
  • 701 Answers
SOURCE: central vacuum with new motor shuts off and throws switch
Your mini breaker is probably bad if its a new motor. Its found on the relay board and they can weaken over time, especially if you had a bad motor before that tripped it a lot.
Posted on Oct 31, 2009
DC07 Shuts Off, won't restart
If it was running for a while... It may be overheating. It has a reset: http://www.ehow.com/how_5943288_reset-dyson-vacuum.html
But maybe just let it cool for an hour or two and try it again?
Oct 07, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vacuum worked just fine... i went in another room to use it and now it won't turn on no matter what outlet i use!
If it works in the other room's outlets, I would think that it might be tripping the circuit breaker for the room it isn't working in. Check your circuit breakers.
Dec 07, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Sep 28, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
I have a BISSELL CLEANVIEW II, I turn the power switch to "on" and am able to clean carpet for 1/2 a minute until the power shuts off in the outlet the vacuum is plugged into! The same repeats itself! I...
well yes in deed it is time for a new vac. for the motor bearings or armature are ceasing up ang causing the breaker to pop. if the vac. cord is hot then you know for sure...
Nov 12, 2009 | Vacuums
Central vacuum with new motor shuts off and throws switch
Oct 31, 2009 | Vacuums
It keeps tripping the breakers or the GFI outlet.
try different outlets in another room to see if that dosent help you may have a shortin the cleaner but i think you may be overloading the breaker
Jan 17, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover Wind Tunnel bagless- issue with turning on
Have you tried to plug the vaccuum in another outlet that is on another breaker? It could be the vaccuum tripped the breaker. Turn the breaker back on. The manual mentions the thermal protector could have been activated. If this happened it resets and your vac should run after 30 minutes. I have a Widepath Tempo and it has tripped the surge protector. If this is the problem try turning some things off that are also on that breaker/outlet, or unplug them when you use the vac.
Jan 04, 2009 | Hoover U6630-900 WindTunnel Bagless...
Unit will not turn on
Unplug the vacuum unit from the wall. If it is hard wired turn off the circuit breaker
Jul 30, 2008 | Broan-NuTone CV450 Central Bagged Central...
Eureka 5893AVZ Bagless Upright Cyclonic Vacuum Logo
1,341 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
