Question about Genius Wayne Submersible Sump Pump With Switch
Sump pump drain
Where does the sump pump in a basement have to be drained to?
  • 3 Answers
In a lot of towns, like mine for example, it is illegal to pump your sump pump water back into your storm sewer (aka drain on the basement floor). I would run at least a 1 1/2" PVC discharge line out of your house and then connect some flexible tube or piping to that to carry it further away from your house.
Posted on Aug 31, 2009
    President:
  • 2,692 Answers
Storm sewer or rain water run off area. In other words , almost anywhere where it won't come back in.
Posted on Mar 12, 2009
Need to run spin cycle only
No, the instructions comes from a programmed chip in the logic board. You can only do spin only if there is a spin only program. You can drop the hose into a large pail after it has done the main pump out. You could also set up an above ground 'sump' and a sump pump with level switch that cuts the power to the washer in the event that the sump pump fails.
Jan 11, 2018 | GE WCVH6260FWW
Sump Pump Ejector line (outside) freezes.
IF the drain on the outside of the home is in the ground and is not below the freeze / frost line, it needs to be changed. If the drain is above ground at any point it needs to be unhooked at the point it exits the structure and diverted to the ground with an elbow. A splash diverter would be placed under the elbow.
Jan 09, 2018 | Washing Machines
Frozen sump pump ejector
what part of the world do you live in
Jan 12, 2014 | Washing Machines
How durable is the comet pumps ?
From my experience they are very durable! I have two pressure washers, and two sump pumps that I have built using these pumps and they hold up to hard use.
The sump pumps are used for draining flooded basement and also new foundation pours flooding. So they have had some hard use. I am in the process of building a sump pump for my daughters swimming pool using their pump also.
One CON - make sure you COMPLETELY drain them in freezing weather AND blow air through them to completely dry them.
Jun 06, 2011 | Comet Bxd2525g Pressure Washer Pump 2500...
I need to pump out a large tub in my basement to my drain because my drain is 8 feet off the floor. do you know where I can buy this pump or what it is called thanks jimmy and susan
you need to get a pump that will push water about 10 feet. sump pump is probably what I would use. Sears usually carries pumps like that as well as Steve Regan Company.
Dec 18, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Jan 27, 2010 | Frigidaire Dehumidifiers
Pump support
Follow these steps to replace a malfunctioning sump pump. If you are starting from scratch and want to put in a completely new sump pump and drain line, you should have a professional plumber do any actual piping unless you have an advaced knowledge of those techniques. Locate the sump pump in your basement. Unplug it to avoid possible electrical shock or personal injury. Find the place to disconnect the pump from the drain line. This is usually either a screw-together type union or a rubber coupling with hose-clamp fastenings. Both are quickly and easily undone. Remove the pump from the pit and allow it to drain for a few minutes. Any plastic piping or fittings that comes from the water outlet opening and goes up to where the pump connected to the drain line needs to be removed and saved to reattach to the new pump. Take the pump with you to your local hardware store, plumbing-supply house or home-improvement center. They can help you pick a replacement that requires the same power source and provides the same drain-line hookups and pumping capabilites. Reattach any piping and fittings in the same way that they were on the old pump. Set the new pump in the pit and reconnect the union. Plug in the pump. You can test the pump by filling the sump pit with buckets of water.
Aug 27, 2008 | Belle Group BHB30 - for 8 gallon Hydraulic...
Installing a Washer in basement
The top of the drain pipe that the washing machine drains in to should be about 3 feet off the ground. If the sewer pipe is higher than that you can either get a longer hose, or drain it into a sump with a sump pump that pumps it into the sewer pipe. If you don't have a sump, first try the longer hose and make sure it drains to a point higher than the sewer pipe (that would be the easiest) or cut a hole in your floor and put in a sump and sump pump (the most difficult).
Oct 08, 2007 | Washing Machines
Vertical draining
Water only runs down hill. To accomplish your task you would need a small condensate pump to get the vertical lift to transfer to your sump. as an example "http://www.hartell.com/corp/details/0,,CLI1_DIV32_ETI3740,00.html"
Aug 09, 2007 | LG Goldstar LD65EL Dehumidifier
Genius Wayne Submersible Sump Pump With  Switch Logo
264 people viewed this question
Top Genius Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Genius Electrical Supply Expert? Answer questions, earn points and help others
