Hai ....am vivek .please help me dears...i have RICOH Aficio 2045 ...it will appears sc 990. What's the solution for this error?? Plz help me ...
    New Friend:
    Problem Solver:
  • 9 Answers
SC 990 is software performance error. This means The software attempted to perform an unexpected operation.
Possible causes:
1. Software defective
2.Internal parameter incorrect
3.Insufficient working memory
4.When SC occurs, the file name, address and data will be stored in NV RAM this information can be checked by using SP 7403. Note the above data and situation in which this SC occurs. Then report the data and conditions to your technical control center.
Posted on Jul 18, 2013
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Posted on Jul 17, 2008
SOURCE: Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Posted on Jan 21, 2009
SOURCE: Error code sc 387 on my Ricoh Aficio 4006
Helo Joe!
Clean charge corona unit and around the drum. If your problem did't stop you must replace the drum potential sensor.
Posted on Feb 23, 2009
Cogz
  • 1326 Answers
SOURCE: ricoh 2045 sc 990 when i fix printer its appear
Did the donner copier have a finisher on it? The code means a miss comunication with the finisher. There is a HD that is used with a finisher. The meter count can not be changed that I know of......The reason it shows 000000 is that the battery was disconnected from the eprom.
Posted on Mar 15, 2009
I have an sc 326 error code in my ricoh aficio 2045 copier
If you wish to get some details; check the site linked here. Pull up older posts....
Jun 19, 2016 | Ricoh Aficio 2045e 2035e Copier...
My machine ricoh 2035 sc code 901 how to remove
my dear total counter error you chek total counter meter
Aug 04, 2015 | Ricoh Aficio 2045e 2035e Copier...
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Error code sc 322 for aficio ricoh 2045
this is a laser unit problem.check laser connections clean the laser unit.
Aug 08, 2011 | Ricoh Aficio 1035 Copier
I have problem in Ricoh AF 2045 SC 990 pl z help me out from it
this is software performance error.but this in most cases will appear on life over of either drum or developer.
Jul 26, 2011 | Ricoh Aficio 2035 Copier
Sc 322 for RICOH AFICIO 2045
That is a LASER error code.
It can be just toner dust because that error is a bad communication between the laser synchronization detector board and the LD unit.
Sometimes the dust of toner goes to the laser and causes this error.
Try to clean the laser unit. Maybe that work
Feb 24, 2011 | Ricoh Aficio 450 Copier
Plz tell me code solution Ricoh Aficio 2045 is problem sc 303 code
That is an error in the yellow drum charging unit.
You can have an arching yellow charge, a bad contact, etc.
It is the high voltage portion of the yellow drum unit.
Nov 10, 2010 | Ricoh Office Equipment & Supplies
Ricoh 2045 sc 990 when i fix printer its appear
Mar 14, 2009 | Ricoh Aficio 450 Copier
228 people viewed this question
k24674
jasbo
jasbo
