Question about Hotpoint RGB745 Gas Kitchen Range
My pilot light will not light on the left side
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
First is the igniter clicking, next are you holding the knob in firmly, can you smell gas? If yes to first two and can't smell gas remove the knob and hold it in with the back end of a screwdriver and re try. If it fires up what is happening is the brass spindle under the knob is not being pushed in far enough replace the knob or try to pack something in the hole of the knob so it will push in further.
Posted on May 10, 2014
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Apr 23, 2013
HOW CAN YOU TELL IF THE PILOT LIGHT IT LIT ON A H200 ABOVE GROUND HEATER
To see if the pilot itself is lit first remove the front cover. Near the bottom left hand side of the cabinet with the cover removed, look just above the burners you will see an oval hole punched out of the front panel. You can look inside the small opening to see if the pilot is burning. You may need to look on a bit of an angle to the left side of the burners and your should see it
May 24, 2014 | Hayward 250kbtu Ng Pool Heater - Inground
Pilot light issue
you cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
Jun 30, 2013 | Ovens
2004 Honda Pilot, right rear brake light doesn`t work. I know it`s not the light bulb because it works for the turn signal and hazard lights.
Chances are that is the bulb. Its a dual filament bulb. The brake portion of it is burnt out. try swapping it with the left side and see if it works then. If it works, get a new bulb.
Apr 17, 2013 | 2004 Honda Pilot
Right stove top burners won't ignite
Your right side burners probably have small vertical lighting holes that are clogged where the pilot lights the burner. Use a sewing needle to poke each hole clean. While you're at it, poke clean the horizontal burner holes just to make sure they are not clogged either. Are there also little tunnels from the burners to each pilot flame? Make sure those are clean inside and attached properly on each end. The pilot flame should be approx 3/8" tall. Compare the working pilot flame to the non-working pilot flames and adjust as necessary. Each pilot has a small aluminum tubing running to it, the adjustment screw will be on this tube. You'll just need a small flat head screw driver to turn it counter-clockwise to increase flame. Hope this helps. Let us know if we can be of further assistance. Douglas
Jun 05, 2010 | Amana ACF3325 Gas Kitchen Range
Where is the Hotpoint RGB524 Gas Kitchen Range pilot light located and how do I get it lit? I turn knobs and hear a spark sound but no flame. Thanks in advance..
The spark should light the pilot automatically. If you open the broiler door and look up at the left rear side of the burner, you should see the pilot assembly and the spark igniter. Try lighting the pilot by hand with a match, right where the spark is. If it lights, the oven should come on. If it doesn't light, there may be a blockage in the pilot assembly, like a spider web or something. If the pilot seems too small, it may set for LP and you are on Natural gas. The adjustment for that is behind the oven knob, a screw. Good luck.
Mar 27, 2010 | Hotpoint RGB524 Gas Kitchen Range
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Pilot light keeps going out on one side of my Tappan stove (TPF303BWA). The 2 left burners are fine but the right side burners will not stay lit. I can light them with a match and they stay on for...
HI, Try using a needle to clean out the pilot orfice. Most models have an adjustment for the pilot light. It would be located near the manifold under the top panel.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 05, 2009 | Tappan TGF303BW Gas Range
Pilot light gone out
My pilot light also just went out on my water wizard 13P when you relight ensure all buttons are equal in height or none depressed then hold far left button down whilst striking ignition button till pilot light ignites keep left hand button depressed for a further 3 seconds after pilot light has ignited I hope you have hot water then
May 22, 2009 | Audiovox Bosch 718 World Cellular Phone
I ran out of propane...so now truck is filling us up..how do I get the oven working again..how to light the pilot light?
Hi there, hope this helps. On the front of the oven, usually on the left side, where your thermostat is, has a red button sticking out, that is your pilot safety. To light it, you need to open the lower door, and aprox. in the center of the area, is your pilot, has a small pipe going to it, you have to hold the red button in, and light the pilot in that lower chamber, and most of the time, once the pilot is lit, you must hold the button for 60 to 90 seconds. If it does not stay lit when you let go of tthe button, you may have additional problems, let us know. And thank you.
Feb 20, 2009 | Bakers Pride Y-600 Gas Single Oven
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Hotpoint RGB745 Gas Kitchen Range Logo
62 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
