Question about Goodman CLQ36AR49 Air Conditioner
GSH140301AC WHAT SIZE IS IT
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
Tip
How to Unlock an Ipod using Windows
If you ever accidently locked yourself out of your iPod this is the easiest way to UNLOCK an iPod
FIRST CONNECT iPod TO COMPUTER/LAPTOP (using a USB cable)
On your desktop click on Microsoft
start button, then choose Run..
type this exactly
J:\ipod_Control\Device
then click
OK
tip: use the letter representing your ipod driver, for example
J...(you can find your letter by clicking
My computer then see your ipod name under that letter)
there will be a file named
_locked
you then right click on it and choose
Rename, you then type
unlocked
then press Enter
OR
you can just
delete the file named _locked
now close window
and
safely disconnect usb driver (this would be either on your icon tray or you could use itunes or any other media player that has an eject button)
CONGRATZ YOUR iPod IS NOW UNLOCKED AND READY TO BE ENJOYED AGAIN
ps...have not tried it, but....
if you have a locked iphone or itouch, this just might work for it too.....
instead of
replace
ipod to iphone or itouch, get it?...
Good!...
Now have FUN!!!
on Jan 15, 2012 | Microsoft Computers & Internet
What bulb is the turn signal bulb on a 2002 oldsmobile alero
On 2002 Oldsmobile Alero Car Light Bulb Size, check this list:
Low Beam Headlight Bulb Size: 9006 or 9006 HID Upgrade KitHigh Beam Headlight Bulb Size: 9005 or 9005 HID Upgrade KitParking Light Bulb Size: 3157NALLFront Turn Signal Light Bulb Size: 3157NALLRear Turn Signal Light Bulb Size: 3157LLTail Light Bulb Size: 3157LLStop Light Bulb Size: 3157LLHigh Mount Stop Light Bulb Size: 921Fog/Driving Light Bulb Size: 894License Plate Light Bulb Size: 194Back Up Light Bulb Size: 921Front Side Marker Light Bulb Size: 194Rear Side Marker Light Bulb Size: 2825Glove Box Light Bulb Size: 194Map Light Bulb Size: 212-2Dome Light Bulb Size: 212-2 or 561Step/Courtesy Light Bulb Size: 168 or 73Trunk/Cargo Area Light Bulb Size: 211-2
Hope helps.
Apr 25, 2012 | 2002 Oldsmobile Alero
How do replace driver side headlight bulb? What size do I get?
Go to your local auto parts store.Ask at the counter,give them your make and model and year.
High & Low Beam Headlamp Light Bulb Size: 9007
Parking Light Bulb Size: 194NA
Front Turn Signal Light Bulb Size: 7507 Or 2827
Rear Turn Signal Light Bulb Size: 7507
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 7506
License Plate Light Bulb Size: 168
Front Side Marker Light Bulb Size: 194NA
Rear Sidemarker Light Bulb Size: 7443
Dome Light Bulb Size: DE3175
Trunk/Cargo Area Light Bulb Size: DE3022
The bulb is in a socket which will twist out,then there may be a clip that holds the bulb in.
Jun 25, 2011 | 2003 Mitsubishi Lancer
Where can convert european shoe sizes to american?
Here you may find a convertion table for shoe sizes.http://www.dancesport.uk.com/shoes/conchart.htm
Oct 27, 2010 | Clothing Accessories
Drivers side brake light and horn won't work,,is it the multi function switch? 1999 chev blazer 4x4 . if so how much does a new one cost?
No there not connected, replace the brake light
1999 Chevrolet Blazer Auto Light Bulb Size Guide
High Beam Headlamp Light Bulb Size: 9005
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 880 or 881
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 161
Map Light Bulb Size: 168 or 211-2
Step/Courtesy Light Bulb Size: 168 or 211-2
Under Hood Light Bulb Size: 93
Instrument-General Light Bulb Size: 161 or 37 or PC194 or PC74
Check Engine Indicator Light Bulb Size: PC74
Hi-Beam Indicator Light Bulb Size: PC74
Seat Belt Indicator Light Bulb Size: PC194
Brake Warning Light Bulb Size: PC74
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: PC74
As for the horn, inspect the fuse and relay and most common it would be a bad ground wire or worst a bad horn due to corrosion. Horn will be located in the drivers side fender.
Thank you for using fixya.
May 13, 2010 | 1999 Chevrolet Blazer
2000 pontiac montana. I want to replace the driving ligh bulbs. the under the headlights what size is it?
Here is the rest of the bulb size used in your Montana.
2000 Pontiac Montana Auto Light Bulb Diagram
Low Beam Headlight Bulb Size: 9004
High Beam Headlamp Light Bulb Size: 9004
Parking Light Bulb Size: 4157NALL
Front Turn Signal Light Bulb Size: 4157NALL
Rear Turn Signal Light Bulb Size: 3156
Ash Tray Light Bulb Size: 558
Dome Light Bulb Size: 562
Trunk/Cargo Area Light Bulb Size: 212-2
Daytime Running Light Bulb Size: 3157NALL
Apr 30, 2010 | 2000 Pontiac Montana
What lamps takes ford focus 2001
This may help
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 3157LL
Front Turn Signal Light Bulb Size: 3157LL
High Mount Stop Light Bulb Size: 2825
Fog/Driving Light Bulb Size: 899
License Plate Light Bulb Size: 6418
Back Up Light Bulb Size: 3156LL
Map Light Bulb Size: 3886X
Dome Light Bulb Size: 6411
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Apr 07, 2010 | 2001 Ford Focus
My license plate lights are out...what kind of bulbs do i need??
Check this reference guide...
2002 Hyundai Accent Car Lightbulb Size Guide
Parking Light Bulb Size: 2357A
Front Turn Signal Light Bulb Size: 2357A
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 2357A
Rear Sidemarker Light Bulb Size: 168
Map Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: DE3022
From Sylvania Lamp Replacement Guide
License plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp.
I hope help you with this. Good luck (remember rated this help).
Sep 09, 2009 | 2002 Hyundai Accent
How to replace headlight on a 2003 Chevy Tracker
There are two black plastic clips behind the the air filter, remove them and release the whole assembly to access the lights.
If you still get in troubles, have it replaced at a petrol station, they will help you in fitting the bulb, and it won't be expensive.
Here follows
2003 Chevrolet Tracker Light Bulb Size Chart
Parking Light Bulb Size: 1157A
Front Turn Signal Light Bulb Size: 1157A
Rear Turn Signal Light Bulb Size: 921
High Mount Stop Light Bulb Size: 168 Or 921
Ash Tray Light Bulb Size: 74
Trunk/Cargo Area Light Bulb Size: 168
Instrument-General Light Bulb Size: 158 or 74
Check Engine Indicator Light Bulb Size: 74
Hi-Beam Indicator Light Bulb Size: 74
Seat Belt Indicator Light Bulb Size: 74
Brake Warning Light Bulb Size: 74
Automatic Transmission Indicator Light Bulb Size: 74
Directional Signal Indicator Light Bulb Size: 74
Oct 02, 2008 | 2003 Chevrolet Tracker
Goodman CLQ36AR49 Air Conditioner Logo
91 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
