Question about OEM 1998 Infiniti I30 Radio / CD Player g64815585g receiver AM-FM-stereo-cassette-CD, Bose, thru 9/97 Akron, Ohio
Stereo volume knob stop working - OEM 1998 Infiniti I30 Radio / CD Player g64815585g receiver AM-FM-stereo-cassette-CD, Bose, thru 9/97 Akron, Ohio
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
Why could my volume knob be stuck on max volume and not adjusting?
There is probably grease or dirt on the contacts inside the unit. Here's a video that shows you how to fix it:
http://www.youtube.com/watch?v=y4XF9PoidJQ
Hope this helps!
Aug 08, 2014 | Marantz SR-4320 Receiver
Car stereo just randomly stop work doesnt allow me to turn up volume or change stations or set it to aux none of the buttons work but the stereos turns on.. what could it be???
Well knowing what stereo you have would help, but mine, the volume knob doubles as the settings knob if you press it. In some newer systems like mine, you should find a "back" button (small arrow) like on a cell phone. Trying using that to escape the settings mode that you might have activated.
May 28, 2014 | Car Audio & Video
Should i spray the inside of the volume knob to fix the volume?
You can try contact cleaner. Spray some in (with unit turned OFF) and move the knob up and down several times stop to stop. then try to see if it helped.
Dec 28, 2011 | Aiwa Audio Players & Recorders
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
Volume knob does not work
Get some tuner cleaner (radio shack etc.) and using the thin straw it comes with, spray generously into the volume knob shafy (removethe plastic knob first). Spray while rapidly moving shaft back and forth. Repeat 2-3 more times and all should be good. You have dust builup inside, causing it to go haywire!
Make sure you do this with the stereo OFF!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 28, 2009 | Jeep AM/FM Cassette with CD Changer...
Broken volume knob
I located the remote control for the unit and it works fine. As the unit is not the primary amplifier for the home stereo system, I use the remote to control the volume. Thank you for your quick responce, and I will keep you in mind for any future needs.
George Keeler
Dec 31, 2008 | KLH R5100 Receiver
Stock radio stopped working
Have you checked the fuses. Usually under the dash or in the glove box.
Aug 14, 2008 | 2001 Dodge Neon
D608 - Volume Problems
I just picked up one at the dump. You have to take apart the front end by unscrewing screws and pulling out ribbon edge connections. It is easier than some components. Then pry off two of the small clamp downs on the front of the volume potentiometer; pry apart about 1/32 of an inch and spray control cleaner for a second and clamp down. repeat on other side.
worked for me.
Bill
Aug 18, 2007 | Pioneer VSX-D608 Receiver
OEM 1998 Infiniti I30 Radio / CD Player g64815585g receiver AM-FM-stereo-cassette-CD, Bose, thru 9/97 Akron, Ohio Logo
67 people viewed this question
Top OEM Car Audio & Video Experts
D. E. Hev
wadingriver
wadingriver
Are you an OEM Car Audio and Video Expert? Answer questions, earn points and help others
