Question about OEM Systems Car Audio & Video
1993 Nissan Pickup truck needs new radio.
How do I remove the old one? Pull trim off, etc?
    Scholar:
  • 67 Answers
Since you didn't provide any Model info, I can't be sure what to tell you to do. Try going to www.InstallDr.com, because they have some great schematics and diagrams for radio removal.
Posted on Mar 13, 2009
How do i remove a radio from a 1993 suzuki sidekick
well thats in the FSM. easy peasy
stock radio , we cant do non stock. (vast )
i guess step 4 is it?
heater control page.
  1. Disconnect the negative battery cable.
  2. If equipped, disable the air bag system. (skip)
  3. Carefully pull the knobs off of the control levers.
  4. On Sidekick, Tracker, Sidekick Sport and X-90 models, grasp the trim panel and pull it off of the instrument panel.
  5. stop.... here.
radio out
electronic version not analog
remove ash tray, and hidden tray screw and tray guide
  1. Pull the heater control lever knobs off of the levers.
  2. On 1996-98 models, separate the heater control trim panel from the control unit by pulling it straight away from the instrument panel. Allow the trim panel to hang loose.
  3. Open the ashtray, then depress the ashtray retainer and remove the ashtray from the sliding track. While it is removed from the vehicle, now would be a good time to wash it out.
  4. Loosen the two retaining screws, then remove the ashtray track from the instrument panel center trim bezel.
  5. On 1989-95 Sidekick and Tracker models, remove the trim panel (Bezel) by prying it carefully away from the instrument panel.
  6. On 1996-98 models, remove the center trim bezel from the instrument panel by loosening the four retaining screws and maneuvering the heater control trim through the appropriate hole. Set the bezel out of the way.
  7. Use a screwdriver to loosen the one rear mounting bracket-to-radio screw; access can be gained to this screw through the ashtray hole.
  8. Remove the four radio front retaining screws, then pull the radio out of the instrument panel just far enough so that the electrical connections on the rear of the radio can be accessed.
  9. Detach and label the wiring from the radio. Also, detach the antenna cable from the rear face of the radio
  10. pull radio. now. (if stock if not stock look for locks)
step 5
Feb 25, 2015 | 1993 Suzuki Sidekick
How do i remove the stock radio from my 1993 geo metro 4 door hatchback
here is the online fsm quote
  2. Open the glove box. Remove the glove box open panel.
  3. Remove the air conditioning switch connector and heater control unit lever knobs. Pull heater control unit cover plate from instrument panel.
  4. Remove the gearshift control lever upper boot and center console.
  5. Remove the ashtray.
  6. Remove the instrument panel center trim bezel and radio face plate.
  7. Remove the screw from the back of the radio receiver and the screws from the front face of the radio.
  8. Remove the radio.
Sep 30, 2014 | 1993 Geo Metro
The exterior door handle on my 1993 Nissan pickup broke. I have a new handle but can't figure out how to remove the inside door panel to get to the area where I can remove the old handle and replace with...
Inside door handle should have some screws that need to be removed and the window crank will have a c-clip behind it . or some you have to pop the cover off the window crank
Oct 14, 2017 | 1993 Nissan Pickup
Can the transmission be removed without having to pull the engine in a 1987 nissan pickup 4 cylinder engine. thanks, emil
yes it can you just remove the bellhousing bolts and all other hardware if its auto than you will need to remove torque convertor bolts manual trans shift linkage etc 4wd transfer case etc
Feb 01, 2011 | Nissan Pickup Cars & Trucks
I need to know how to take the old stereo out of my 1999 buick regal to put in my new cd player? i cant figure out how to get the dash out
Hi, here is the procedure from autozone.com. Please let me know if you have any questions, and thanks for using FixYa.
Removal & Installation
  1. Obtain the THEFTLOCK® codes and radio station presets before attempting to remove the radio, if applicable.
  2. Disconnect the negative battery cable.
  3. Remove the trim plate bezel from around the radio using the following procedure.
    1. Adjust the steering wheel for access.
    2. Remove the ignition switch cylinder bezel.
    3. Remove the left side instrument panel fuse block access opening cover.
    4. Remove the instrument panel cluster trim plate screws.
    5. Starting at the right side of the instrument panel cluster trim plate, grasp the trim plate and carefully pull rearward. Continue working around the trim plate until all of the retainers are released from the trim pad.
    6. Detach the electrical connectors from the hazard switch and remove the trim plate from the vehicle.
  4. Remove the screws from the radio and pull the radio gently from the instrument panel.
  5. Detach the instrument panel wiring harness connector and the antenna cable connector from the radio.
Fig. You must remove the instrument panel cluster trim panel in order to remove the radio assembly
To install:
  1. Installation is the reverse of the removal process, noting the following:
    1. After the electrical connection is secure and the antenna cable is connected, find the radio locator tab.
    2. If the locator tab is difficult to align to the instrument panel locator opening, pull the radio towards you and reposition the antenna cable.
    3. Gently install the radio to the instrument panel, aligning the radio locator tab to the instrument panel locator opening while carefully pressing the radio into the instrument panel until fully seated.
  2. Install the trim plate bezel.
  3. Connect the negative battery cable.
  4. Unlock the THEFTLOCK® radio (if applicable).
  5. Program the radio stations back into the radio as recorded at the beginning of this procedure (if applicable).
Jan 28, 2011 | Car Audio & Video
How to remove the car stereo from 2007 Chevy Colorado
This is not hard but tricky because the trim plate around the radio has clips that hold the trim plate very tight.Use a plastic type flat tool or flat screw driver wraped with tape or a shop rag to avoid damage to the plastic trim and pry the trim panel around the radio loose. remove all elec connectors.Then remove the screws that hold the radio in place and remove all elec connectors.
Jan 30, 2010 | 2007 Chevrolet Colorado (Extended Cab) New...
Removing factory radio from 2000 Nissan Frontier XE
There are two screw at the bottom of the black plastic trim panel around the radio. Remove the screws and pull the trim panel back. Remove the four screws around the radio, unplug the wires on the back of the radio and you are finished!
Aug 15, 2009 | 2000 Nissan Frontier
My 1993 Nissan truck will not start. I hear a faint clicking sound, but the starter will not turn over.
Sounds like the starter, starter solenoid maybe. If you pull out the old one you can either test it at home or take it to Autozone. They will test it for free.
Jul 01, 2009 | 1993 Nissan Pickup
How do i remove the radio from a 2007 nissan sentra 2.0 i want to replace it
Remove the trim around the shifter, then remove the center console. You will then have access to the screws holding the trim around the radio in. Once you are to that point, take the radio screws out and pull out the radio.
Nov 28, 2008 | 2007 Nissan Maxima 3.5 Sl Sedan
Car Audio & Video Logo
147 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
