Question about Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier
I don't believe I am getting the maximum amount of output from my amp. Nothing near 100 watts of sound. Would it have anything to do with the EQ settings?
Was out jamming the other night, had the amp at 5 and was using an RP500 and still I had someone at the bar tell me I could not be heard. What is up with that?
  • 575 Answers
Speaker placement, might have to try some different locations or tilt back a little.
Posted on Apr 24, 2013
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
I have two sp2 speakers i am using a ipod numark dj machine connected through my 2600 watt peavey amp it keeps blowing out one speaker can you tell me why
The SP2 speakers are rated at 1000 watts PROGRAM which is around 500 watts RMS MAXIMUM. You should be using an amp capable of a maximum of 500 watts a side... Your amp is WAY too big. You will have to throttle it down. The speakers have the protection for the tweeters but NOT for the woofers. At five hundred watts RMS and 8 ohms the current is: P = I^2 * R so I^2 = 500/8 = 62.5 so MAX current is 7.9 amps. I recommend you put a 8 amp FAST BLOW fuse in the speaker leads. If the fuse blows, you have saved another speaker and you are DRIVING them too hard. For greater safety make the fuse a 7.5 amp fast blow. Also get a sound meter. The max on these speakers is 125 Db at a meter distance... and in your venue you should NOT exceed 100 Db to be safe with the OSHA regulations regarding hearing protection... I suspect you are driving the speakers too hard. One side may be getting more bass. The speakers are rated down to 55 Hz. DO NOT boost bass up as you will overheat the speakers. If you are using microphones, be careful of feedback, especially that above hearing range. If you need real low bass, then get an 18 inch subwoofer. No matter, stay within safe sound levels to avoid lawsuits and hearing loss... I know several deaf musicians...
Jul 07, 2011 | Music
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
Could you send me the best set up starting with 1 for setting up our new XR 8600 Powered mixer in our church. We have 3 bose loudspeakers on each speaker output. Should those Bose be set for 100 watts...
Sorry, but you have a problem. The amp is rated to 4 ohms per side. Your speakers would have to be 16 ohm type to allow 3 per side in parallel. The Bose ratings are usually consumer type ratings and they would have to be set to 200 watts each (twice the rating that the amp can produce per side) to be safe connected to that amp. Your speakers are likely 8 ohm so you could parallel ONLY two per side OR if they are 4 ohm, then you would have to series them. You could series two or three per side safely for the amp. You don't tell us what model Bose speakers you have. Anyway, one has to first meet the specs of the amp and the speakers to avoid damage. It is likely the amp is too BIG for the speakers. For the setup of the mixer portion of this problem I want you to view videos on YouTube. Search for "mixer setup". Don't worry that they are different mixers than yours... there is enough commonality and the functions are nearly the same for MOST analog mixers. Recommendation: forget about two of the speakers... keep them as spares and run low volume to avoid blowing the speakers. I can't imagine any competent audio equipment supplier configuring your system this way.
Apr 24, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
How can a PMP 2000 be patched so that both internal amps are used to power the monitors, and the mains are sent from the mainpre-out to another power amp, while using one internal eq for the mains, and the...
No you can't quite do this since the EQ's are right before the power amps in the signal flow. The monitor output would drive two 8 ohm speakers daisy chained at roughly 300 watts RMS... I can't imagine needing more than that for a venue that is within the capabilities of this unit.
You can drive both power amps by the monitor output by setting the mon/main function on the switch and using a short TRS cable jumper between MONITOR PREAMP OUT and the RIGHT POWER AMP INPUT jack. Drive your mains from the LEFT PREAMP OUT. The EQ's will ONLY affect the monitors. Use an external EQ if you need to EQ the mains with this connnection. Use TRS balanced cables to the main amp and CONNECT all interconnected equipment to the SAME power source or receptacle, even if it means running an extension to the mixer.
Apr 05, 2011 | Behringer PMP2000 800 Watt 10 Channel...
Marshall Mg 100DFX power on no sound it just cut out last time i played it.The fan has issues I wonder if there is a cooling sensor shutting down the amp output.I thought solid state amps were bullet...
Something has probably failed or become a bad joint. If you turn up the gains and volume to max is there any hiss or hum from the speaker? If not there will be a problem in the power amp or power supply. Check fuses at back. The speaker may be open circuit too, that is easy to check with a multimeter. If you can't get far yourself, you'll need a repairman.
Solid state amps are not that reliable these days, there are so many things that can fail due to all the effects that people demand to be built in. Look at how many people are reporting problems with ss amps here.
Apr 02, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Fender ultra deluxe amp volume max out a number 7 volume control. will not get any louder
It is likely that the amp is flat topped at the 7 setting. When the amp is producing the maximum voltage output it is capable of, that is ALL you can get out of it... The numbers on the dial mean NOTHING and are only relative. If you have high output guitars you might find the maximum might only be 3 on the dial for example...
If you need it louder, get a bigger amp and speakers. You should ALSO get a sound meter and follow OSHA guidelines for sound exposure... I know several musicians that now are nearly deaf because of being exposed to high sound levels... their music careers are now gone as they can no longer hear well enough. You need to protect your hearing for the long term. Great musicians don't need loud, but quality and inovation in their music.
Jan 07, 2011 | Music
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
Dec 04, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
For 100 watts it doesn't seem that loud to me. Could I maybe add more speakers (2x10s)?
Our human perception of loudness can be way off. You should get a soundmeter and compare. There are some pretty good ones on eBay new for about $140.
Adding speakers may NOT increase the sound much as the power will then be split between the speakers.
Nov 02, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Open Questions:
See all Fender Frontman 212R 100W 2x12 Guitar Combo Questions
Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier Logo
53 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
